AKS-4m Russian Arri 35 copy
12 replies to this topic
#1 Stefan Fischer
Stefan Fischer
  • 46 posts
  • Deutschland
Posted 04 November 2017 - 02:47 PM
Today was a good day for me
Was looking for a long time for this AKS-4 camera.
The camera set has never been used and is in new condition
It is a very nice and well made Arriflex 35 copy.
Can someone tell me more about? Cant find near zero
Infos about it on the internet
Thanks in advance
Stefan
#2 Dom Jaeger
Dom Jaeger
  • 1837 posts
  • Melbourne, Australia
Posted 04 November 2017 - 11:38 PM
Great! Congratulations!
I've never seen one before. Any photos of inside?
#3 Stefan Fischer
Stefan Fischer
  • 46 posts
  • Deutschland
Posted 05 November 2017 - 02:28 AM
As soon I got it, I will post much more pictures also of the inside
#4 Stefan Fischer
Stefan Fischer
  • 46 posts
  • Deutschland
Posted 05 November 2017 - 02:56 AM
It is a full set in the original box
#5 aapo lettinen
aapo lettinen
  • 1173 posts
  • Finland
Posted 05 November 2017 - 09:23 AM
saw one sold on ebay couple of years ago and never after that, seems to be quite rare camera. the lens mount is its own but some Ukrainian and Russian ebay sellers sometimes confuse the aks mount to the much more common oct18 mount even when the diameter and appearance is different. so it is possible to find some extra lenses for it if you're lucky.
the aks mount has a heavily slanted groove's edge on the mount and a slant at the end of the mount too, when oct18 has a narrower more of a straight cut groove with possibly only tiny slanted edge and the end of the mount is usually pretty much straight cut with no slant.
you can spot them from the images even if the description is incorrect.
there is old Soviet propaganda/doc stuff on youtube etc. where you can see these cameras used for example for filming nuclear tests (having multiple aks's in a row pointed to the test area)
https://youtu.be/INSTW8xfKU0?t=46
#6 Kyryll Sobolev
Kyryll Sobolev
  • 82 posts
  • Toronto
Posted 06 November 2017 - 12:04 PM
this is from russian interwebs
AKS was a family of cameras designed for aerial photography
the letters stand for Apparat KinoS'emochnyj, which means, as you can easily guess - Cinema Apparatus
(not very creative branding... as you know, the soviet lenses were marked OKS - Ob'ektiv KinoS'emochnyj, or, Cinema Lens)
AKS-4 was copied from Arriflex 35 designs captured in the war (so says russian wikipedia)
this site here has a little more info - http://kinofototeh.ucoz.ru/index/0-88
in 1938 Lenkinap started making documentary cameras KS (direct copy of Eyemo)
AKS was a modification of KS - changes included the viewfinder, an added hotshoe (or something like it) to attach an aerial gunsight, and instead of a detacheable crank they added a crank with a reduction mechanism to make it easier for a pilot to load the spring
if i'm not mistaken, AKS series were manufactured by KMZ (Kransogorsk Mechanical Factory)
Edited by Kyryll Sobolev, 06 November 2017 - 12:05 PM.
#7 Stefan Fischer
Stefan Fischer
  • 46 posts
  • Deutschland
Posted 12 November 2017 - 03:52 PM
Got the camera last Friday
It is identical to the Arri 35
Except the lens mount.
Can someone please translate #8 and #9 on the picture
#8 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 12 November 2017 - 04:02 PM
Google says:
8. Power supplies:
a) Direct current system, B,
B ) Rechargeable battery, B
9. Battery capacity, Ah 13
Edited by Samuel Berger, 12 November 2017 - 04:02 PM.
#9 Stefan Fischer
Stefan Fischer
  • 46 posts
  • Deutschland
Posted 12 November 2017 - 04:43 PM
Thank you
Still not sure how much Volts it needs
#10 Kyryll Sobolev
Kyryll Sobolev
  • 82 posts
  • Toronto
Posted 12 November 2017 - 04:57 PM
according to that picture: 27 volts (+/- 2.7 V) from a plug, or 12-15 V from a battery
27 volts was (and i think still is) standard power supply on aircraft
there is, of course, a GOST for that - http://docs.cntd.ru/...st-r-54073-2010
#11 Stefan Fischer
Stefan Fischer
  • 46 posts
  • Deutschland
Posted 12 November 2017 - 05:00 PM
I tried it with 12 volts but it doesn’t run on 24fps then
To weak
So I will give it a try with 27
Thank you
#12 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 12 November 2017 - 05:02 PM
My Arri 2C requires 16V to run at 24fps. In real life that's 16.8V.
#13 Stefan Fischer
Stefan Fischer
  • 46 posts
  • Deutschland
Posted 12 November 2017 - 05:06 PM
I will give it a try with 24
Should work
By the way - the inside is identical to the Arri 35
And it is not as loud as a Arri
