Shooting Vertical with Aaton XTR - How to?
9 replies to this topic
#1 Lee Robinson
Lee Robinson
  • 11 posts
  • Toronto
Posted 20 November 2017 - 11:32 AM
Hey everyone,
I have a project i want to shoot on 16mm and im exploring the idea of shooting vertically as they are moving portraits.
The camera i can get access to is an Aaton XTR. I cant find any information online about anyone else having shot vertically with this camera. Does anyone have any suggestions on how this could be securely rigged? Is it possible? And are there any other implications that i havent thought of, mechanically or other, of why this wouldn't work?
Thanks and sorry if im missing something really obvious!
Lee
#2 Mark Dunn
Mark Dunn
  • 2904 posts
Posted 20 November 2017 - 11:34 AM
How will the material be presented, because what you describe will have people on their backs (or stomachs) in the frame. Sounds odd.
#3 Lee Robinson
Lee Robinson
  • 11 posts
  • Toronto
Posted 20 November 2017 - 11:48 AM
I guess im wondering if there is a way that the camera could be rigged on its side on the tripod - so the subject would be able to stand/sit as normal.
#4 Samuel Berger
Samuel Berger
  • 1266 posts
  • Seattle
Posted 20 November 2017 - 12:50 PM
He understood what you meant. The question is, how will you show the finished product to the world? Like a vertical iPhone video?
Yes you can rig the camera sideways. That's one way of doing it. Or you shoot it normally then you can crop it in post to the aspect ratio of an iPhone video.
#5 Lee Robinson
Lee Robinson
  • 11 posts
  • Toronto
Posted 20 November 2017 - 12:56 PM
I would scan/digitize the negative and it would be playing on a vertical screen..
It seems a waste to crop it in post.. it would be a lower resolution?
What parts would i need to rig the camera sideways so that the weight would be balanced safely?
Thanks so much for the help,
#6 Tyler Purcell
Tyler Purcell
  • 4471 posts
Posted 20 November 2017 - 02:24 PM
L bracket from home depot and the proper threaded wing nuts and screws, should work fine. Then you just use the normal tripod head with a sliding baseplate, to adjust the "offset" so the camera is centered in the right place.
The camera will work fine sideways.
#7 Lee Robinson
Lee Robinson
  • 11 posts
  • Toronto
Posted 20 November 2017 - 05:07 PM
Hey,
Thanks so much for the advice!! Could you by chance recommend which tripod might be good for the weight? I'll be using Zeiss primes..
#8 Brian Drysdale
  • 5343 posts
Posted 20 November 2017 - 07:48 PM
Try a Ronford F7.
#9 Mikołaj Syguda
Mikołaj Syguda
  • 7 posts
  • Warsaw, Poland
Posted 22 November 2017 - 06:20 PM
I guess the safest way to put camera in that position is to use Dutch Head. You can rent it in some well equipped rentals. Then you have 3 axis with your tripod head. It's safe, we've used it for Alexa, worked just fine.
#10 Dom Jaeger
Dom Jaeger
  • 1928 posts
  • Melbourne, Australia
Posted 22 November 2017 - 07:29 PM
The only caveat I would add is that I have come across an XTR that was damaged due to being held vertically by the 3/8" thread in the base, which deformed the housing at the bottom and damaged the electronic boards inside. I don't know what loads were put on the camera, or if it was jolted by a car rig or something, but it's something to be aware of. Probably fine with small primes and a stable tripod.
