problem with sony dvw 790 digi beta
#1 oscar jimenez
oscar jimenez
  • 317 posts
  • PANAMA, REPUBLIC OF PANAMA
Posted 04 July 2005 - 07:07 PM
Hi, a friend of mine just shot some scenes on which the director asked him to switch from std 4:3 aspect ratio to 16:9. when he switched, the image on monitor looked out of focus ( like when back focus is moved from its proper position ) he did grab focus again, adjusted back focus, image was the same, what's curious is that in the view finder, it looked ok ( in focus ) and in the monitor out of focus, he then checked previous footage on playback, and it looked ok, so the problem was not the monitor or video cable, anyone has any clue on this? can be the swtich from 4:3 to 16:9 make this happen? should some parameter in the menu be taken in consideration for adjustment when doing this? Thanks for any clues.
Oscar
Posted 04 July 2005 - 07:23 PM
Was it a 16x9 monitor?
#3 oscar jimenez
oscar jimenez
  • 317 posts
Posted 05 July 2005 - 10:35 AM
Indeed, Mr Mullen, monitor was 16:9 switchable, Lens on aprox of 50mm on the zoom and a stop about F 4.0 . Playback looked ok sharp on focus, image on viewfinder also did appear in sharp focus, when switched to 16:9 aspect, image on monitor was soft focus, but looked sharp on VF, also playback looked ok from some previous scenes.
Thanks so much indeed.
Oscar
#4 David Mullen ASC
Posted 05 July 2005 - 10:39 AM
I can't understand what the difference would be between a 16x9 signal coming live from camera into the monitor versus a recorded 16x9 signal coming down the same cable, and why the live signal would look out-of-focus on the same monitor. Sounds like a maintenence problem with the camera.
#5 Phil Rhodes
  • 12167 posts
Posted 05 July 2005 - 06:10 PM
There are two sets of many adjustments for the 4:3 and 16:9 modes on many monitors; try playing back the wide material in 4:3 mode and check if it's in focus there.
Phil
