I tried with tripod head rigged to position the camera on the pan control knob, and it work, but it's not clean, because of the camera weight(and it's a 5D).
Do you have suggestions?
Edited by Francesco Glavina, 29 December 2017 - 03:57 PM.
![]() Rotate Camera on Lens Axis
Started By Francesco Glavina, Dec 29 2017 03:56 PM
#1
Posted 29 December 2017 - 03:56 PM
What is the best way to rotate the camera on lens axis smoothly (and cheap)?
I tried with tripod head rigged to position the camera on the pan control knob, and it work, but it's not clean, because of the camera weight(and it's a 5D). Do you have suggestions? Thanks Edited by Francesco Glavina, 29 December 2017 - 03:57 PM.
#2
Posted 15 January 2018 - 10:02 PM heavy-duty steel L bracket from hardware store - mount the camera lens to the sky on it, and your tripod plate to the other side of the L. Lay your tripod on a table/platform/box of some kind and strap it down so the head is hanging off the end a short amount. Use the pan axis of your tripod to spin around the lens - adjust the fore/aft slide on your tripod plate to center the lens on the center of the sticks. Real "improvised" but cheap and effective with a lightweight camera like that.
#3
Posted 17 January 2018 - 03:41 PM You could rent a Lambda head for this task as well.
On a recent job production rented a letus helix (or something similar) for because they needed this effect on a steadicam. Edited by Akos Baranya, 17 January 2018 - 03:42 PM. |
