Converting 220v editor to USA?
#1 Daniel D. Teoli Jr.
Daniel D. Teoli Jr.
  • 84 posts
  • Born in L.A....NYC is 2nd home...Rustbelt is home base.
Posted 09 January 2018 - 02:35 PM
I bought 2 editors from Europe. (Zeiss Moviscops) The only issue with them is they are 220v. They only had 2 wires in the 220v plug, so I thought it would a simple thing to exchange the plug to USA style. While they did light up, the bulb only gives off half the light it should and picture is hardly visible.
Any advice on how to make them brighter?
Edited by Daniel D. Teoli Jr., 09 January 2018 - 02:37 PM.
#2 Mark Dunn
Mark Dunn
  • 2639 posts
Posted 09 January 2018 - 03:02 PM
Many editors were made for worldwide sale so it may have adjustable taps for 110V- there may be a plug on the casing. Just switch it over to 110V.
Or you could just do a search of the forum
Edited by Mark Dunn, 09 January 2018 - 03:12 PM.
#3 Daniel D. Teoli Jr.
Daniel D. Teoli Jr.
  • 84 posts
Posted 09 January 2018 - 05:15 PM
No adjustments on old plug but will look at previous discussion.
Thanks!
#4 Gregg MacPherson
Gregg MacPherson
  • 1925 posts
  • New Zealand
Posted 09 January 2018 - 09:15 PM
The bulb is only getting half its designed voltage, so it will run at half the Watts, hence brightness.
Solutions might be to source 110V bulbs, hopefully the easy solution, or a small transformer with 220/240V output.
Make sure there isn't a 240/110V switch somehere on the machine first.
Edited by Gregg MacPherson, 09 January 2018 - 09:17 PM.
#5 Mark Dunn
Mark Dunn
  • 2639 posts
Posted 10 January 2018 - 04:39 AM
The bulb is low-voltage fed through a transformer, not mains voltage.
