General advice for 1st time using redheads
Redhead
28 replies to this topic
#1 Simon Danaher
Simon Danaher
  • 11 posts
  • UK
Posted 20 January 2018 - 08:50 AM
This is my 1st post so hi to everyone, I've lurked for a bit and have been impressed by the very helpful replies, the forum is a great resource for learners like me.
I'll be shooting a music video shortly and have bought some used photon beard 800w redheads but have never used them before. I've read they can explode and shouldn't be kept on for long periods. Is that correct?
I'm a photographer and cgi artist by day so I have experience and intuition with lighting but with studio strobes not continuous lights and not in such a big space (a hangar).
We were planning on using 120-400w worklights for practicals, a lot of tight shots and close lighting, the 4 redheads are a bonus that I picked up very cheap. Am I right in thinking the power of the redheads will give me more options for wider shots in a big space? Limited budget meant I was going to shoot around what light we had and just keep the bg black, but I'm thinking I might actually be able to light it now?
What else do I need to know regarding safely using redheads? Common pitfalls, etc. Any general advice and tips from pros would be very much appreciated.
#2 Brian Drysdale
  • 5282 posts
Posted 20 January 2018 - 11:02 AM
Lamps can explode, it can happen with any tungsten halogen light, not just Redheads.  You should put a safety glass or at the very least safety wire onto the light, Photon Beard or their agents should be able to supply these for you.
I've never run into a running limit with Redheads, I've had them running for hours without a problem, However, wear gloves if you're going to adjust the barndoors, since these get hot.
Switch them off if moving them, otherwise the bulb life can be reduced.
Redheads are good workhorse lights, however, you've got limited control with the barndoors and they are best for putting light through diffusion or bouncing it..
Fresnel spots offer much more control overall
Edited by Brian Drysdale, 20 January 2018 - 11:03 AM.
#3 Simon Danaher
Simon Danaher
  • 11 posts
  • UK
Posted 20 January 2018 - 11:49 AM
Thanks Brian that's really helpful. I haven't picked up the lights yet but pics show they come with a wire mesh and also a glass pane.
I should buy some spare bulbs too I guess. Any recommendations there? Stick to branded or not necessary?
#4 Adrian Sierkowski
  • 7485 posts
Posted 20 January 2018 - 12:21 PM
Make sure when you're handling the bulbs you DONT TOUCH THE GLASS (well Quartz) of the bulb. Wear leather gloves, and/or use an alcohol wipe when touching the thing and wipe off any finger grease which may get on there with the alcohol wipe.
For redheads generally they are most useful as a bounced source or going through a frame of diffusion. Rarely would you want to use them directly on someone as they aren't the most flattering light in the world. They could work well as a back-light, however, and in such case a little cut of Opal on the doors can help them look a big better and even them out a bit.
That said they're nice lights. I had quite a few myself which I bought for a steal ($25 each!) many moons ago, but got rid of them as I divested myself from owning equipment (not so much so necessary in Los Angeles as it was in Philadelphia).
As for the lighting; I would wonder why the BG of the shot needs to be lit? If it's a Music Video it might be ok to let the BG fall off on it's own anyway and to keep focus just on the talent in the shot. That said, you could do some fun up-lighting with the red-heads.
I would also think about getting dimmers on them, just to control output and/or warm them up color wise if you're into that kind of thing.
#5 Simon Danaher
Simon Danaher
  • 11 posts
  • UK
Posted 20 January 2018 - 01:26 PM
Thanks Adrian. Good advice about the bulbs, I wouldn't have know that, I'll make sure I bring gloves.
Re the BG, yes until I get in there I won't really know if it'll be usable lit (haven't seen it in person yet). I wasn't planning on using the redheads to light the talent, but maybe I should consider it. Dimmers also a good idea, will look into it.
thanks!
#6 Levin Liebig
Levin Liebig
  • 7 posts
  • Berlin
Posted 20 January 2018 - 08:35 PM
I usually just use toilet paper or something similar to change the bulps. The important thing is that no oil of your skin comes in contact to the glass.
Most redheads have a grid in the front preventing shards from the bulb flying into your actors face. (That sounds really bad :huh:  but that is not likely at all.)
One more important thing is to remember to relief the strain on the cable. So if someone trips over the cable, the lamp will not fall. It will also help to prevent the cable braking where it enters the case of the lamp.
#7 Brian Drysdale
  • 5282 posts
Posted 21 January 2018 - 05:08 AM
I've had a redhead bulb explode a few times and I've also see the bulb particles land close to people in the days when the safetly glass wasn't always used.
This can happen with fresnel spots, this has been the highlight of a live news or TV programme on a number of occasions.
https://www.youtube.com/watch?v=l2VCFuRWUls
https://www.comedy.c...xploding_light/
Edited by Brian Drysdale, 21 January 2018 - 05:10 AM.
#8 Simon Danaher
Simon Danaher
  • 11 posts
  • UK
Posted 21 January 2018 - 05:35 AM
Thanks guys. I saw a YT video of a guy showing the wire screen from a burst redhead bulb. It had a hole right through it. That's what made me think I should only use them for the BG or at a considerable distance from people. That said it was probably cheap Chinese kit rather than the Photon Beard units I've bought. Picking them up today, so I'll know exactly what and how many safety guards they come with.
Its an industrial location so I'm not expecting any issues powering everything but getting them into position is a bit of a worry due to the size of the space and as yet I have no idea where the power points are located. If current draw is Watts/Volts that's about 3.3A per light on 240v mains IIUC. Would that mean I could safely run 3 redheads off a single 13A 240v extension cable if need be?
#9 Brian Drysdale
  • 5282 posts
Posted 21 January 2018 - 06:09 AM
In the UK you won't have a problem with the standard 13 AMP plug, you can easily run 3 lights from one plug.
Personally. I'd go with safety glass over the wire mesh, it stops the small particles and I've seen the glass working when bulbs explode. You then don't have to worry about the cast and crew, because, in practice, people will be close to the lights.
Edited by Brian Drysdale, 21 January 2018 - 06:17 AM.
#10 Mark Dunn
Mark Dunn
  • 2797 posts
Posted 21 January 2018 - 08:22 AM
You won't be able to space the lights very wide apart if you do, but if you do run them all off a single extension, make sure it's fully unwound. 10A will melt the lead if it's still rolled up.
#11 Brian Drysdale
  • 5282 posts
Posted 21 January 2018 - 10:29 AM
Put each light on it's own extension lead, you can either use a multi socket tail or string them out from each other, using extensions with double sockets,. The latter is very flexible, but don't save on the cable lengths and use cable that can carry a full 13 Amp load, the lead on the redhead basically gets you to the base of the light stand.
#12 Simon Danaher
Simon Danaher
  • 11 posts
  • UK
Posted 21 January 2018 - 10:33 AM
Thanks again guys, great stuff. I was wondering if daisy chaining extensions is OK or not, max length of 13A extension I've seen on a spool is 50m.
#13 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 21 January 2018 - 11:21 AM
You can daisychain extension cords, but as they get longer (over 100ft) you'll start to get voltage drop, which will make the lamps run dimmer, and warmer in color. As the voltage drops, the current will increase. If you are using the cable at close to its maximum load, the increase in amps will cause the cable to heat up, and possibly even melt.
If you have to do long cable runs, reduce the load on each one.
#14 Brian Drysdale
  • 5282 posts
Posted 21 January 2018 - 11:54 AM
On long runs I'd use a higher capacity cable than you usually get on the extension spools, which are OK for running a lawnmower, It's rare that you need 50 metre runs unless you're  shooting exteriors.
Edited by Brian Drysdale, 21 January 2018 - 11:57 AM.
#15 Mark Dunn
Mark Dunn
  • 2797 posts
Posted 21 January 2018 - 12:22 PM
There's a reason for that.
I've run blondes off 50m, but it wasn't the standard 13A gauge. Maybe 20m tops for one of those. Actually our lawnmower is more powerful than a redhead!
Just another reminder to unspool it all so it doesn't end up doubling as an electric heater.
#16 Brian Drysdale
  • 5282 posts
Posted 21 January 2018 - 12:36 PM
Yes, but you maybe running more than one redhead on a cable, so cable suitable for blondes is the type to go for.
#17 Simon Danaher
Simon Danaher
  • 11 posts
  • UK
Posted 21 January 2018 - 06:32 PM
I'd like to setup in the centre of the hangar so I'm anticipating some longish runs of cable. if 20m gets me there I'm good as I already have some of those (they will be fully unwound :) can't afford heavier gauge cables so I'll just have to keep an eye on it.
Of the 4 redheads one is an Ianbeam (sp?), I notice it's a fair bit brighter than the photon beards but still 800w, could it be a shinier reflector?
#18 Brian Drysdale
  • 5282 posts
Posted 21 January 2018 - 06:50 PM
The reflector does make a difference, the Quartz Color Ianebeam  (the original Redhead) does have a untextured reflector and gives out a bit more than some other brands
#19 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 21 January 2018 - 08:28 PM
Also, newer globes do tend to burn brighter than old ones.
#20 Simon Danaher
Simon Danaher
  • 11 posts
  • UK
Posted 22 January 2018 - 04:21 AM
Good point re globes. Ah yes the Ianebeam reflector is untextured. Not sure if that affects the quality of the light, both looked nice and even, but definitely different in quality somehow...I'll have to recheck the focus settings. I suppose it won't hurt to give all the reflectors a bit of a clean as well.
