HDV Analogue/FireWire Output
#1 Nashville
Nashville
  • 1 posts
Posted 06 July 2005 - 05:15 AM
Does anybody know if there`s a difference in quality between the analogue and firewire sony-hdv-camera output?
(is the analogue output before the hdv-compression-processing?)
Which is the better way:
1.analogue output>Aja-card>HD-SDI>Postproduction
2.firewire output>lumiere/connect HD...>Postproduction
3.firewire output>miranda hdbridge>HD-SDI> Postproduction
best regards, steffen.
#2 David Cox
David Cox
  • 323 posts
  • Digital Image Technician
  • london, UK
Posted 06 July 2005 - 06:22 AM
Hello,
Not sure what difference there would be between the analogue out and the firewire (definitely worth a test) but do note that VTR tape control is only available by firewire. So if you wanted to use the camera as a playback deck (or indeed the HDV playback deck itself) you will need the HD Connect to do firewire to RS422, assuming you need that connection for your post tools. A NAB, the miranda box only did video/audio - not control.
Alternatively, you could just copy all your rushes "wild" to another format with new time-code.
David Cox
Baraka Post Production
www.baraka.co.uk
