High-speed lighting
#1 Paul Tackett
Paul Tackett
  • 78 posts
Posted 29 January 2018 - 04:22 PM
Hello I'm lighting for 1000 fps. In the equation I originally compensated for shutter speed but I believe the following is now correct using shutter angle if you could please help if you know.
I used the equation: 100asa at 180degree shutter, 24fps = 100fc at 2.8
For high speed I got: 800iso, 180degree, 998.4fps = 520fc at 2.8
Do I need to compensate for shutter or is this correct? Thank you
#2 Paul Tackett
Paul Tackett
  • 78 posts
Posted 29 January 2018 - 04:25 PM
With this in mind a 12k Big EyeSolorspot at full spot at 20 is 5900fc & 950fc full flood. Factor in diffusion cutting at least by half I'm thinking I could probably do medium spot and have exposure with one unit on the back edge
#3 David Mullen ASC
  • 19970 posts
Posted 29 January 2018 - 04:54 PM
1000 fps is something like a 5+ stop loss compared to 24 fps, and going from 100 ISO to 800 ISO is a 3-stop gain, so you need another 2-stops of exposure, so a bit more than 400 fc instead of 100 fc? So your 520 fc might be right, off the top of my head...
#4 Paul Tackett
Paul Tackett
  • 78 posts
Posted 30 January 2018 - 11:11 AM
I appreciate it, thank you David for all your help.
#5 Paul Tackett
Paul Tackett
  • 78 posts
Posted 30 January 2018 - 04:05 PM
Another question regarding this. Can a skypanel with the 3.0 update shoot flicker free at 1000 fps? Considering using a couple s60's and getting more top down light.
#6 David Mullen ASC
  • 19970 posts
Posted 30 January 2018 - 04:37 PM
http://www.arri.com/...s-new-features/
Looks like youll be fine. Dont know what the speed limitation was before. An older post suggests that the pre-3.0 upgrade was flicker-free at 2400 fps.
#7 Paul Tackett
Paul Tackett
  • 78 posts
Posted 30 January 2018 - 05:15 PM
Thank you David. Thats pretty high, great to know!
