Cleaning A7s ii sensor
sensor
10 replies to this topic
#1 Mario Bosanac
Mario Bosanac
  • 19 posts
Posted 01 February 2018 - 10:41 PM
Hello all,
So my friend owns an Sony A7s ii and it has an issue. As you can see from the videos and pictures it seems that there seems to be lint/dust on the sensor. What would be the best way to clean that out manually. I have camera cleaning gear of my own.
I've posted a dropbox shareable link because they're too big if files.
https://www.dropbox....6hbzSdfwxa?dl=0
Any suggestions would be great! Thank you!
#2 Samuel Berger
Samuel Berger
  • 1199 posts
  • Seattle
Posted 01 February 2018 - 10:59 PM
https://www.amazon.c...e/dp/B00017LSPI
#3 Mario Bosanac
Mario Bosanac
  • 19 posts
Posted 01 February 2018 - 11:04 PM
I have this equipment yes, but it's NOT on the front of the sensor, it's on the back of the sensor. Should have clarified that
#4 David Mullen ASC
  • 20175 posts
Posted 01 February 2018 - 11:21 PM
There shouldn't be dust there... you might need to send the camera in to be serviced.
#5 Robin R Probyn
Robin R Probyn
  • 2348 posts
  • Tokyo
Posted 02 February 2018 - 12:45 AM
Do you mean behind the OLPF.. which is infront of the actual sensor.. ?.. but very unlikely dust would get in there.. unless it was from new or has been taken out before in a non dust free room..  end of the day.. if its not a simple clean take it in.. you will end up doing more damage and could brick the whole camera..
#6 Mario Bosanac
Mario Bosanac
  • 19 posts
Posted 14 February 2018 - 05:51 PM
Update: it's a smudge. Any add'l suggestions?
#7 Dom Jaeger
Dom Jaeger
  • 1784 posts
  • Melbourne, Australia
Posted 14 February 2018 - 06:20 PM
If you've tried cleaning the cover glass with more than just a blower (I use swabs with alcohol myself) and find the smudge is indeed underneath, I would recommend sending the camera to a professional repair centre or back to the manufacturer.
  • 1
#8 Mark Dunn
Mark Dunn
  • 2780 posts
Posted 15 February 2018 - 04:59 AM
I think you've just saved me some money. I was using Eclipse fluid from a kit but when it runs out I've got a couple of pints of isoprop. Thanks.
Folks, if Dom uses it, it's OK.
Edited by Mark Dunn, 15 February 2018 - 04:59 AM.
  • 1
#9 Dom Jaeger
Dom Jaeger
  • 1784 posts
Posted 15 February 2018 - 10:15 AM
Thanks for the vote of confidence Mark! I hope you spend your saved money wisely. ;)
I find 9 times out of 10 isopropyl alcohol cleans a sensor cover glass just fine, but occasionally you need something with a little more bite to get a stubborn speck off, which is when I will use a cleaning fluid like Eclipse or Pancro. A loupe helps to inspect the surface to see if you've cleaned it properly.
#10 Mark Dunn
Mark Dunn
  • 2780 posts
Posted 15 February 2018 - 10:26 AM
Ciggies and drink.
Edited by Mark Dunn, 15 February 2018 - 10:38 AM.
#11 Mario Bosanac
Mario Bosanac
  • 19 posts
Posted 19 February 2018 - 04:10 PM
Found the solution guys! Found specific wipes for the sensor. Thank you for your comments & suggestions! Happy filming!
