Can anyone identify this mattbox ?
11 replies to this topic
#1 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 06 February 2018 - 08:33 AM
This ia a 3inch x 3 inch mattbox ( presumably Arri ? ). Had it for years and I fitted a central bracket so it can be used on mattbars.
But does anyone know what camera it was originally designed to fit via the off centre square bracket. ? (its not aaton)IMG_5942.JPG
#2 Robin R Probyn
Robin R Probyn
  • 2401 posts
  • Tokyo
Posted 06 February 2018 - 08:39 AM
Arri BL 16mm had a Mattbox like this.. from what I remember.. I assisted a guy who had one many years ago..
Aaton was 15mm rod mount..
Edited by Robin R Probyn, 06 February 2018 - 08:40 AM.
#3 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 06 February 2018 - 08:46 AM
The early Aaton mattboxes fitted onto the square handle rod, but this has a different offset to centre.
#4 Robin R Probyn
Robin R Probyn
  • 2401 posts
  • Tokyo
Posted 06 February 2018 - 08:59 AM
oh ok before my time.. the only ones I used were on the rods.. but that Mattbox is from an Arri BL 16.. Im pretty sure of that.. but it wouldn't be the first time if Im wrong.. but I would bet a beer and a KitKat without any doubt in my mind..
#5 Brian Drysdale
  • 5287 posts
Posted 06 February 2018 - 09:26 AM
I had an Arri bellows matte box like this with my Aaton LTR as supplied by ICE films. The matte box was intended for the Arri SR but they made some changes to fit it on the Aaton , but I later had the later Aaton lightweight support bar system fitted to the camera, since their square system never really worked..
Edited by Brian Drysdale, 06 February 2018 - 09:30 AM.
#6 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 06 February 2018 - 09:50 AM
Yes Brian, I had the lightweight bars fitted too. But the offset of this mattbox would never have fitted the Aaton anyway.
#7 Nojus Drasutis
Nojus Drasutis
  • 66 posts
  • Lithuania
Posted 06 February 2018 - 10:54 AM
Looks similar to Konvas mattebox.
(Sorry, It's not, my fault)
Edited by Nojus Drasutis, 06 February 2018 - 10:56 AM.
#8 Brian Drysdale
  • 5287 posts
Posted 06 February 2018 - 11:23 AM
From memory the  square bar went on right of the Aaton (based around the Aaton handle bars) ,in a sort of swing away arrangement, which never seemed to work that well..
#9 Robin R Probyn
Robin R Probyn
  • 2401 posts
  • Tokyo
Posted 06 February 2018 - 07:02 PM
isn't it like this.. well this looks an older version.. think they could be used on any 16mm Arri.. the old ST and SR,s .. is your 3 x3 you say.. not 4 x 4 ..?
Edited by Robin R Probyn, 06 February 2018 - 07:10 PM.
#10 Brian Drysdale
  • 5287 posts
Posted 07 February 2018 - 04:00 AM
My Arri matte box had a couple 3 x 3 or 4 x 3 trays, one of which could be rotated using the silver wing seen at the top. If you removed the tray a 4 x  4 filter could be fitted if needed.
The 16BL matte box didn'r have all the filter tray options, since the filter acoustically sealed the front of the camera.
#11 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 07 February 2018 - 05:00 AM
Brian, Mine has the trays with the silver wings , just not in the shot. 3x3 inch filters...but take the trays out and a 4 inch filter can be used ( with some tape! ).
Robin, the one you show is a different design, I beieve.
#12 Robin R Probyn
Robin R Probyn
  • 2401 posts
  • Tokyo
Posted 07 February 2018 - 05:40 AM
Yes I think your right.. its an older type.. But I recognize those silver wings.. maybe the guy I assisted with a BL had used this newer type.. but that square rod thing was the same set up on top..
