Flagging Tips?
light control flagging
#1 Seth Baldwin
Seth Baldwin
  • 44 posts
  • Australia
Posted 07 February 2018 - 08:36 AM
Got a gig that will require a lot of soft street light outside. My question doesn't really relate to our lighting setup but more a question regarding the science and possibilities of controlling light.
So we have 2 Arri M40's each separately going through 8 x 8 diffusion frames right across the road from each other, pointing in roughly the same direction, except one is directed more across the road and one is pointing more down the road, any way long story short we need to create more separation and mood to the scene and have many 4 x 4 floppy's and 2 x 6 cutters. Since a substantial amount of light is needed to be lost from one side of the diffusion frame and the fact that the more diffused a source is the harder it is to dramatically cut it, is there a better way besides basic flagging to control extremely flooded light from a big diffusion frame?
#2 Jaron Berman
Jaron Berman
  • 193 posts
  • New York, NY
Posted 07 February 2018 - 09:35 AM
LCR grids, "fabric egg crates", lighttools grids - Most grip houses will carry the usual sizes like 8x8, kinda like an instant directionality to your 8x without adding much depth (about 2-3").  The angles tend to be relatively accurate if you're flying the frame flat like a door, butterfly it tends to get a little tighter pattern at the edges as the grid wants to slump in the middle.  Placing flags in front of that directional 8x can further help separate certain areas, so you get the full "bang" of the frame but with clever placement of flags you can only "show" parts of it at a time using parallax.
  • 1
#3 Robin R Probyn
Robin R Probyn
  • 2384 posts
  • Tokyo
Posted 07 February 2018 - 09:46 AM
Posted these pics on another thread.. the same problem as you .. large soft source that needed control .. but for green screen.. and these grids worked incredibly well.. Im sure they dont have to honey comb.. but a deep enough grid really helps alot..
  • 1
#4 Seth Baldwin
Seth Baldwin
  • 44 posts
  • Australia
Posted 07 February 2018 - 09:47 AM
awesome guys, thanks for that. I'll contact the rental house
#5 Phil Rhodes
  • 12298 posts
Posted 07 February 2018 - 10:34 AM
You know, reading this thread, I wonder if one of the things about the hexes is that they don't sag so much.
  • 1
#6 Ryan Emanuel
Ryan Emanuel
  • 31 posts
Posted 07 February 2018 - 11:13 AM
It depends on how much room you have between the source and the edge of frame.  Egg crates can work and would be easiest, but know that your output will reduced.  Also make sure the degree of the eggcrate will create the desired effect. An alternative would be if you have the room for a 12x8 or even better a 16x8 sider of black that will probably the trick as long as that doesn't enter frame.  Common misconception that a sider of the same size as the diffusion will be able to fully control the spill.  It all depends on the angle, some times you need a sider twice as big as the diff frame to control it.
#7 Albion Hockney
Albion Hockney
  • 486 posts
  • LA
Posted 07 February 2018 - 11:45 AM
^ exactly. Eggcrate is usually used for tighter spaces. It gives the illusion of a big soft source far away that is flagged off on the sides.... but if you have big sources far away you can just use big solids.
#8 Seth Baldwin
Seth Baldwin
  • 44 posts
  • Australia
Posted 07 February 2018 - 03:19 PM
What you guys reckon, just a 4x4 floppy and a cutter will do the trick?
#9 Robin R Probyn
Robin R Probyn
  • 2384 posts
  • Tokyo
Posted 07 February 2018 - 07:45 PM
Yes you would still need flags too..with the grid..Im not saying that.. but it does help alot..(we had a ton of space).. compared to without ..with big enough lights... the amount of light being cut by the grid was minimal .. thats really only a concern with small lights..
Yes I guess Hex maybe is less prone to sagging.. must be some reason they went with that design.. it was pretty firmly clamped onto its own frame about 10cm deep..  the whole thing on wheels.. genius..
