Wall spreader from joined 2x4s?
wall spreader safety
7 replies to this topic
#1 Rick Gates
Rick Gates
  • 32 posts
  • Eugene, OR
Posted 08 February 2018 - 04:49 PM
I'm getting the hardware to make wall spreaders out of 2x4s.  But I'm anticipating a problem.
The maximum length 2x4 my vehicle can handle is 8 feet.  Is it safe to join a couple of 2x4s to make a longer span for the wall spreader?
As I'm not seeing any 2x4 coupling hardware, I'm thinking maybe this just shouldn't be done.
#2 JD Hartman
JD Hartman
  • 1785 posts
  • Edison, N.J. U.S.A.
Posted 08 February 2018 - 06:04 PM
Get a speedrail spreader.  Get double duty out of your pipe.
#3 Rick Gates
Rick Gates
  • 32 posts
  • Eugene, OR
Posted 08 February 2018 - 06:12 PM
JD, I thought about that.  I was thinking it would be easier to cut 2x4s than speedrail, but it would be nice to get double duty out of the pipe.
Do you consider joining 2 pieces of speedrail for a wall spreader to be safe?
#4 JD Hartman
JD Hartman
  • 1785 posts
Posted 08 February 2018 - 07:58 PM
Not nearly as risky as the wood.  I wouldn't take two ten foot pieces and make a 20, but I'd add a few feet to an end with a coupling if I had to.
#5 Rick Gates
Rick Gates
  • 32 posts
  • Eugene, OR
Posted 08 February 2018 - 08:33 PM
Hmm, if you had to span 24 feet, would you consider 3 eight-foot pieces of speedrail?  Or would that be tempting the fates too much?
#6 JD Hartman
JD Hartman
  • 1785 posts
Posted 08 February 2018 - 09:21 PM
24 feet?  I'd be using truss.  You really need to consider the structural strength of the speedrail and the amount of deflection at the center for a given load.  You're starting to veer way off course to where off the cuff advice doesn't apply, but real engineering calculations do.
  • 2
#7 Rick Gates
Rick Gates
  • 32 posts
  • Eugene, OR
Posted 09 February 2018 - 12:50 AM
Yeah, I'm gonna play it safe and design a different shot.
Thanks for all the tips.
#8 Rick Gates
Rick Gates
  • 32 posts
  • Eugene, OR
Posted 10 February 2018 - 12:10 PM
Aha!  Discovered that I can get away with a 13' span for the shot.
Also saw that Dave Donaldson at the Youtube channel "Grip Tips" recommends joining two pieces of speedrail with a coupling to make a larger span.  Here's a grab from his video:
I think I'm going with this technique.  I can get the Modern Studio wall spreader kit at Barn Door for $80, and their couplings are $33 each.
Also tagged with one or more of these keywords: wall spreader, safety
