My First Menace Arm
menace arm boom speedrail pipe boom
#1 Rick Gates
Rick Gates
  • 30 posts
  • Eugene, OR
Posted 19 February 2018 - 05:26 PM
Well, I just finished putting together my first menace arm.  I joined two 8 foot pieces of speedrail with fixtures from Barn Door Lighting.  Here's a shot:
[img]https://static1.squa...rmat=1500w[/img]
It seemed to go well except for one thing.  I had a hard time balancing the rig because no matter how hard I cranked down on the lollipop in the middle, the boom would move slowly up or down on it's own.  I even followed the right-hand rule.  Here's a picture of the ear inserted into the lollipop:
[img]https://static1.squa...rmat=2500w[/img]
Am I doing this right?
Edited by Rick Gates, 19 February 2018 - 05:35 PM.
#2 Tristan Noelle
Tristan Noelle
  • 63 posts
  • North Hollywood, CA
Posted 19 February 2018 - 06:40 PM
You need another ratchet strap going from the back end of the arm (where your sandbag is hanging) to the base of the combo stand. You leave it loose and get the risers to the right height then ratchet the strap to place the load at the right elevation. It keeps the light from dropping. Other than that, it looks pretty good.
Tristan
#3 JD Hartman
JD Hartman
  • 1769 posts
  • Edison, N.J. U.S.A.
Posted 19 February 2018 - 06:48 PM
5 demerits for not having a safety cable from the fixture to the arm.
One stand leg should be in-line with the arm.
https://products.mse...-5-magic-349581
Should be a fiber, rubber or aluminum friction disc, part #8 between parts #7 and 10.  Missing?
Is your arm nearly balanced or a little rear weighted?  Shouldn't take much force to lock it in position.
#4 Rick Gates
Rick Gates
  • 30 posts
  • Eugene, OR
Posted 19 February 2018 - 07:51 PM
Yeah, I can see why the Kupo head is cheaper ($56 vs $92).  I do have a rubber gasket, but the metal on both sides of it is smooth, not grooved like the Matthews.  Check it out:
Kupo+Grip+Head+01.jpg?format=500w
Since there are grooved surfaces between the two main metal discs in the head, I tried putting the ear in there, and it seems to hold better.  I have about 12 ft of the speedrail in front of the ear, and about 4 ft behind it.  It can be balanced as long as I incrementally add the right number of sandbags.
Right you are about the safety cable.  Can't let that potted palm suffer.
Thanks JD, as always.
#5 JD Hartman
JD Hartman
  • 1769 posts
Posted 19 February 2018 - 08:10 PM
Try cutting another rubber disc from a piece of auto inner tube. Sandwich the ear in between them.
  • 2
#6 Rick Gates
Rick Gates
  • 30 posts
  • Eugene, OR
Posted 20 February 2018 - 01:00 AM
I might start with a piece of a 1/8 inch thick silicon mat that I cut into shapes to keep things from slipping.
Great idea, thanks.
Also tagged with one or more of these keywords: menace arm, boom, speedrail, pipe boom
