Why Bigger is Better (but not much else) S35mm vs. Alexa LF Comparison
large format alexa signature primes arri vistavision alexa lf cinematography
#1 Mark Kenfield
Mark Kenfield
  • 1196 posts
Posted 28 February 2018 - 09:32 AM
G'day everyone,
So, I compared some stuff and wrote a thing:
http://dreamsmiths.c...t-not-much-else
If you're interested in the objective differences of large format cinematography to regular S35mm images, you might find it worthwhile.
It's a quick test comparing regular S35mm Alexa, matched for both field of view and depth of field against the shiny new Vistavision-sized sensor of the Alexa LF, using spherical lenses.
If you click through to the vimeo link, you can download the full 4.4k ProResHQ file in all its glory, which I'd highly recommend pulling into a piece of grading software to look at up close.
The test certainly helped clarify a few things for me.
Cheers,
Mark
#2 Macks Fiiod
Macks Fiiod
  • 1507 posts
  • Og from DC, Now in NJ
Posted 28 February 2018 - 10:36 AM
Is there a clear difference? Yes.
I just can't see it being a 5 digit difference though.
#3 David Mullen ASC
  • 20191 posts
Posted 28 February 2018 - 11:21 AM
Thanks for the test, it goes along with my thinking, which is that the main advantage of larger sensors is less noise and usually more resolution -- the lower depth of field is there too but you can get a shallow focus look in S35 if that's important.  I suppose if someone makes a T/2 zoom for full frame then you can get a shallow focus look while still using zooms, which might be interesting.
#4 Mark Kenfield
Mark Kenfield
  • 1196 posts
Posted 28 February 2018 - 11:28 AM
I think it becomes quite interesting with zooms. I was hoping to put my Zeiss CZ.2 zooms on the camera, but unfortunately they didn't have an LPL to PL adapter with them when I did the test.
At T/2.9, the Zeiss 28-80mm CZ.2 becomes equivalent to an 18-52mm T/2 zoom on S35mm, and the 70-200mm CZ.2 becomes equivalent to a 45-130mm T/2. So you'd get the benefits both of zooming and shallow depth of field all in one.
Also tagged with one or more of these keywords: large format, alexa, signature primes, arri, vistavision, alexa lf, cinematography
