Arrisun 12 refurb
10 replies to this topic
#1 Steve Falcon
Steve Falcon
  • 7 posts
  • Washington
Posted 02 March 2018 - 02:05 PM
I picked up an old Arrisun 12 with EB 575/1200 High Speed in good shape for the age. I've refurbished both, so I've seen the ins and outs of each. A couple questions, as I'm new to HMI.
The USHIO lamp loaded in the fixture has a loose base. The adhesive blobs that would attach the ceramic base to the glass of the par is gone, and the holes where the leads enter the par are not sealed. I assume that the sealed beam enclosure is supposed to be a vacuum, right? It clearly isn't given this condition.
The lamp fires up and looks great, but I'm going to assume it shouldn't be run in this unsealed state. Thoughts?
Also, where to get those lamps? Is there a less expensive option than the ~$500 price I am seeing for USHIO (e.g. https://www.filmandv...ht-ushio.html)?
#2 Ed Conley
Ed Conley
  • 123 posts
Posted 02 March 2018 - 04:32 PM
I don't think they are vacuum sealed enclosures for those Par 64 style bulbs. There isn't a need for them to be.
#3 Matthew Parnell
Matthew Parnell
  • 291 posts
  • Electrician
  • Brisbane, Australia
Posted 02 March 2018 - 04:36 PM
Filmandvideolighting.com has Koto 1200 SE Globes for US $170.
If you stick with brands like Koto, Osram, GE and Ushio you should be fine.
Globes shouldnt be used with physical damage. Once youve seen a HMI or larger tungsten lamp explode, youll understand why.
#4 Steve Falcon
Steve Falcon
  • 7 posts
  • Washington
Posted 02 March 2018 - 04:59 PM
I'm not seeing a Par64 1200W HMI there for $170, just single-ended globes in that price range.
Not sure why my link above is broken. Trying again: https://www.filmandv...ight-ushio.html
#5 Matthew Parnell
Matthew Parnell
  • 291 posts
  • Electrician
Sorry I didnt realize youre after the old old style Arrisun 12 sealed beam globe. Good luck with that.
#6 Phil Rhodes
  • 12320 posts
Posted 02 March 2018 - 06:02 PM
I think that's why those are often found going cheap - the lamps cost a fortune.
The spendy part of the equation is the ballast, though. Most of the 1.2K PAR HMIs I've seen had magnetic ballasts, which are far less useful, so if you have one with an electronic ballast that deals with flicker-free and silent modes, you've done well regardless.
#7 Steve Falcon
Steve Falcon
  • 7 posts
  • Washington
Posted 02 March 2018 - 06:22 PM
Yes, I'm happy with the ballast. Seems to work well and looks great after refurb. 50' leader in good shape too.
#8 Adrian Sierkowski
  • 7496 posts
Posted 02 March 2018 - 06:56 PM
I don't think you'll find a cheaper sealed bulb.
I don't think the bulbs PAR enclosure needed to be a vacuum, but honestly, I'm not 100% on that.
#9 Phil Rhodes
  • 12320 posts
Posted 02 March 2018 - 07:13 PM
If in doubt, get a Photon Beard Platinum Blonde head and run it off that ballast (check that'll work, but I'm fairly convinced it will.)
1200W HMI Blonde.
Very powerful.
#10 Ed Conley
Ed Conley
  • 123 posts
Posted 05 March 2018 - 06:14 PM
http://rstvisions.com
  • 818.566.1114
Ask for Marsella they have 18 left.
$320.00
#11 Steve Falcon
Steve Falcon
  • 7 posts
  • Washington
Posted 05 March 2018 - 06:20 PM
818.566.1114 - Ask for Marsella
Thanks for the pointer..
