Super 16 Lens on a non Reflex Bolex H 16
#1 Mark J St Hilaire
Mark J St Hilaire
  • 6 posts
  • Manchester, New Hampshire
Posted 07 March 2018 - 11:52 AM
Can one use a Super 16 Zoom Berthiot Lens on a Bolex H16 Non-Reflex (Vintage 1949)? Will there be any visual distortions? Thank You. Mark J St Hilaire
#2 Frank Wylie
Frank Wylie
  • 58 posts
  • Culpeper, VA
Posted 07 March 2018 - 01:29 PM
Depends.
You will probably have back-focus issues trying to use that lens IF it was originally manufactured and intended for a Reflex Bolex.  The flange-depth of non-reflex C mount lenses is different from reflex C mount lenses.  Reflex lenses have a longer flange-focal distance than non reflex to accommodate the reflex prism.
https://erkanumut.wo...lex-h16-lenses/
You could remove the pressure pad on the Bolex, place a bit of frosted film in the gate, mount the lens and check for sharp focus.
This is, of course, very difficult to see, even with a magnifier, as the gate is at an angle.  An uncommon accessory, the gate prism, would certainly help here...
https://www.ebay.com...2wAAOSwz~paJ6eN
To be extremely picky, the lens is centered incorrectly for the standard film aperture, but that shouldn't pose too much of an issue in all practicality...
#3 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 07 March 2018 - 01:36 PM
What do you mean by "super16 Berthiot zoom"?
The Berthiot zooms were designed long before super16 even existed. They're made for regular 16mm and should work fine on your H-16.
