HMI UV TESTING
#1 Shachar Alfie
Shachar Alfie
  • 16 posts
  • Israel(Middle East)
Posted 08 March 2018 - 04:30 PM
how can I test that the uv filter in my hmi fixtures Block all UV ?
#2 Phil Rhodes
  • 12175 posts
Posted 08 March 2018 - 05:08 PM
You send it to a lab. It's expensive.
You can get UV shielded HMI lamps now, which gives you an extra layer of confidence.
#3 Shachar Alfie
Shachar Alfie
  • 16 posts
Posted 08 March 2018 - 05:18 PM
thanks
for 2500w hmi koto is the only UV Block option.
I also want to test my old double ended hmi.
#4 Phil Rhodes
  • 12175 posts
Posted 08 March 2018 - 05:34 PM
Yes, it's a nice idea to be able to test. You could probably jury-rig some sort of approximate test.
The problem is, you're doing it for safety reasons, presumably. This means that if the test isn't done properly, in a way that an insurance company would understand and be willing to cover, then that test is of very little value.
I would suggest that if it's properly-maintained equipment made by a reputable company and used properly, it probably is safe, but the only way to verify that in a meaningful way is to take it to a laboratory that's properly set up to perform that sort of testing. I don't even know what certification a lab would need in order to do that sort of work, but places that claim to be able to do it exist.
I was quoted about UK£600 (around US$900) to test one item.
#5 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 08 March 2018 - 06:11 PM
Why do you have a concern?  Is it a PAR?  Do you always use it with a lens?  Is it a Fresnel?  Doesn't operate without the lens door closed which blocks most of the UV, just like the PAR lenses.  In either case, there is a minimum safe distance that should be maintained between HMI fixtures and talent.  That is spelled out by the manufacturer.
#6 Phil Rhodes
  • 12175 posts
Posted 08 March 2018 - 07:34 PM
Note that certain PARs, which have been used with discharge lighting including MSR, CMH and HMI, have been found in the wild with lenses that are not sufficiently UV-blocking for safety. ETC's Source Four PAR was supplied with lenses which are adequately UV-blocking for use with a 575W HMI. Some of the clones of the Source Four PAR have used lenses which were not; at a car show, several of the scantily-clad women on the booth went home with sunburned shoulders.
It is a real concern and actual problems have occurred.
#7 Shachar Alfie
Shachar Alfie
  • 16 posts
Posted 09 March 2018 - 03:51 AM
It is just a general concern as an owner and operator of hmi fixtures(work safety).
I do not always know the history of the fixtures.
UV AB Light Meter
https://www.ebay.com...XMAAOSwEeFVQPSK
