Flashlights as Practicals
#1 Rob C. Givens
Rob C. Givens
  • 5 posts
  • North Carolina
Posted 08 July 2005 - 12:14 AM
Does anyone know what kind of bulbs one would put in a large maglight to get the beam effect, like in Seven.
I've got a scene with only flashlights and moonlight as the sources and need the high power bulbs to help illuminate the scene. Any recommendations on types or brands?
Rob C. Givens
Posted 08 July 2005 - 12:17 AM
For really bright beams, you need to get a high-powered flashlight like a Surefire or Streamlight. Not cheap.
Otherwise, create your own flashlight with some MR-16 bulbs, probably spot bulbs, and a hidden power cable. You'd have to find a body that you can gut and the bulb will fit into.
The room needs to be evenly hazed with a smoke machine / hazemaker to see the beams. You may get enough of an affect with ordinary maglights so do some tests.
#3 Rob C. Givens
Rob C. Givens
  • 5 posts
  • North Carolina
Posted 08 July 2005 - 12:49 AM
Surefire or Streamlight. - are these cinema/specialty fixtures..?
Can I find MR-16 bulbs at your normal hardware store or are these a specialty lighting purchase?
Offtopic :> David - I recently met you with the North Carolina School of the Arts group in early June. - I really appreciate your respect for the growing cinematographers out here. Your knowledge has been quite helpful.
Thanks for the quick response.
#4 David Mullen ASC
Posted 08 July 2005 - 01:35 AM
Just do some searching on Yahoo:
http://www.surefire....r/367/sesent/00
http://www.surefire....r/362/sesent/00
http://www.streamlig...om/products.htm
Here's a photo of an MR-16 bulb:
http://www.ccl-light...lamps/sure.html
You can find them in hardware stores or lamp stores. Don't ask me how to wire them, etc. because I haven't tried it myself. But it can't be hard to figure out. I guess you need a transformer though.
#5 mrbill762
mrbill762
  • 27 posts
Posted 08 July 2005 - 07:18 AM
You can get MR16 lamps in some hardware stores however the will be very expensive.
I get mine on ebaY on boxes of 10 much cheaper that way.
I think you will want to get the 12 volt ones.
They run much cooler and are not as sensitive when bumped or jostled.
Also a power source will be easier to fashion.
Let us know how you make out.
Mr. Bill
<{POST_SNAPBACK}>
#6 Phil Rhodes
  • 12175 posts
Posted 08 July 2005 - 07:37 AM
There are MR-16s, or the smaller MR-11 which comes in 5W and upward. I think the smallest MR-16 is 20W, which you could reasonably run from a hidden battery pack. You can get AA cells in 2400mAh rating, which ought to run a 20W MR-16 for... well, at least a few minutes, and could be worn as a low-profile beltpack under clothing. Otherwise, just figure a story reason for them to be using super high power flashlights, and put a PAG brick or similar on a belt mount.
Phil
#7 Rob C. Givens
Rob C. Givens
  • 5 posts
  • North Carolina
Posted 08 July 2005 - 11:48 AM
Thanks for all the suggestions guys. I'll have to talk to my gaffer and figure out what will be the easiest to rig up...
It's two kids holding the flashlight - so the lighter the better.
Great help, Thanks again.
