First Super8 film problem - processing or me?
#1 Luke Cho
Luke Cho
  • Warsaw
Posted 03 April 2018 - 12:24 PM
Hi All,
I just started my adventure with super8 shooting and after receiving (part of) digitalized film I'm curious what did happen with it. Is it me, who did something wrong or processing and digitalization problem, that killed the film? I attached 2 similar frames with similar scene and difference between them is clearly visible (so it's why I think its processing problem).
I used Canon 514XL-S and Kodak 50D.  (and unfortunately the tungsten filter was on)
#2 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 03 April 2018 - 01:39 PM
The film you had processed is Negative Film. It will need to be transferred to a video or digital file so that the Negative Image can be turned Positive.
#3 Luke Cho
Luke Cho
  • Warsaw
Posted 03 April 2018 - 02:10 PM
Indeed, it looks way better after inverting colors. So it was me ;) Thank you so much!
#4 Robert Houllahan
Robert Houllahan
  • 1615 posts
  • Providence R.I.
Posted 04 April 2018 - 12:21 AM
That is a truly terrible scan.
  • 2
#5 Jon O'Brien
Jon O'Brien
  • 377 posts
  • Brisbane
Posted 04 April 2018 - 02:18 AM
That stone wall in the image looks rather Solomonesque.
#6 Luke Cho
Luke Cho
  • Warsaw
Posted 04 April 2018 - 03:03 AM
I agree with you. But I hope the final version will be better (the guy who does it for me has some issues with the scanner, hope he will solve them soon).
#7 Mark Dunn
Mark Dunn
  • 2638 posts
Posted 04 April 2018 - 03:18 AM
I'd be wailing too if I'd got that back from the lab.
It's so awful I can't tell what the problem is but I'm no expert.
#8 Jon O'Brien
Jon O'Brien
  • 377 posts
  • Brisbane
Posted 04 April 2018 - 08:29 PM
I'm amazed by the quality difference of scans of real film. Some I've seen online just look amazingly good. Almost as good as seeing film projected. Some are amazingly terrible, and many are just mediocre. Why is that? Is it the equipment used?
#9 Perry Paolantonio
Perry Paolantonio
  • 508 posts
  • Boston, MA
Posted 05 April 2018 - 07:23 AM
That's part of it. But each scanner/telecine is different and requires someone who knows how to use it. It's not *just* about the hardware, though that's a very big part of it. Money isn't everything, but you simply won't get results even in the same ballpark with a $5000 scanner as you will with a $100,000 scanner. There's a reason they cost more.
In the example above, whoever scanned it either didn't use a scanner that can invert the negative, or they did it incorrectly -- so right off the bat there are going to be issues. Getting a proper positive image isn't just about flipping the colors, because color neg has an orange cast. This is why film scanners do a base calibration - to judge the density of the clear part of the image, and effectively "neutralize" it to make it properly clear. This is typically done with either a physical blue filter, or a bluer light. Once that's done, the image is inverted. But it's going to be a little different for each film stock (though stocks within the same family -- such as all the Vision3 stocks -- typically work with the same calibrations). Also, if the scan was done to MP4, that's a major red flag right there (though that may just have been a secondary viewing copy, not the actual flat scan).
  • 1
