Canon Scoopic 16 (Original) Meter Question
Canon Scoopic 16
#1 Ryan Fleet
Ryan Fleet
  • 44 posts
  • Editor
  • Buffalo
Posted 04 April 2018 - 06:57 AM
Just recently I picked up an old Grey model Canon Scoopic. I re-celled the batteries and now I'm checking the functions of the camera to see what works.
The battery check on the camera reads properly but when I switch to auto exposure mode and half press the shutter the meter inside the viewfinder doesn't move no matter how bright or dark the object is. Also, when I switch to manual mode and move the aperture from 1.6 to 22 the viewfinder doesn't lose any light its just as easy to see through the viewfinder at 1.6 as it is at 22. With nothing working, I set it to manual and look down the lens barrel to see if I can see the aperture opening or closing inside the lens when I move from 1.6 to 22 but nothing looks like its moving in there either.
Anyone who has used a Canon Scoopic original or M, MN, MS ever run into this problem?
I'm new to this camera system and 16mm but it seems that something is wrong with my aperture not engaging.
#2 Will Montgomery
Will Montgomery
  • 2114 posts
  • Dallas, TX
Posted 04 April 2018 - 09:41 AM
You should notice the viewfinder getting darker or brighter as you adjust the aperture. You won't see blades or anything like that but it will get darker or lighter. Sometimes I find myself opening it up all the way to focus then putting it back to where it should be although this can be dangerous if you forget to set it back.
It could be some sort of disconnection between the aperture ring (that's not on the actual lens but on the smaller meter lens) and the aperture. You should see a difference as you manually move it. You can still shoot a test roll and make notes of the aperture as you shoot to see if it's really changing or not.
#3 Ryan Fleet
Ryan Fleet
  • 44 posts
  • Editor
  • Buffalo
Posted 04 April 2018 - 10:04 AM
Will, unfortunately manually moving the aperture shows no difference in the viewfinder brightness. It's easy to see and focus at F22 just like at F1.6 so there is definitely a problem like you suggested.
Before shooting a test roll I think I'm going to give Barry at super16inc a call, especially since I just realized he is only an hour away from my hometown. I'll see what the cost is to fix and get a CLA for the camera. After further messing with the camera I just got the auto aperture to work and manually moving the aperture I can now see the blades inside the lens opening and closing so I know they are working but still the viewfinder brightness stays the same through all stops.
I rather be putting money into repairing a Scoopic 16M, MN, or MS instead of this Grey one but I can't even find one of those cameras for sale.
#4 Will Montgomery
Will Montgomery
  • 2114 posts
  • Dallas, TX
Posted 06 April 2018 - 12:59 PM
It could be that the original Scoopic's viewfinder isn't affected by the change in aperture but I doubt it...I see I substantial difference in brightness as aperture opens and closes on the MS...
If you get it to work it will be a great camera to have even as a backup.
#5 Ryan Fleet
Ryan Fleet
  • 44 posts
  • Editor
  • Buffalo
Posted 07 April 2018 - 12:05 AM
I spoke with Bernie from super16 today and he was pretty sure that the viewfinder doesnt loose light in the original scoopic. But he will check it out while he is doing the CLA for the camera.
Ill be sending it out to him on Monday with a 2-3 week turn around as long as nothing else is wrong with it. Im pretty excited to get the camera back and run some film through it.
Thanks for your all your help and feedback
Also tagged with one or more of these keywords: Canon Scoopic 16
