Film shot on Krasnogorsk-3, Flicker and
#1 Jan Ruzicka
Jan Ruzicka
  • 10 posts
  • Planet Earth
Posted 10 April 2018 - 03:37 PM
I shot the following on my K3, this is my first 16mm camera. It is modified to shoot super 16mm.
I would like to achieve an image with less flicker and if possible more stable, less "jumpy".
I was thinking on upgrading my camera to a great working condition Bolex SBM to solve these issues.
In your experience, will that upgrade suffice, or will I be looking at similar results?
Should I consider other cameras instead?
Thanks for the help!
Edited by Jan Ruzicka, 10 April 2018 - 03:39 PM.
#2 Brenton Lee
Brenton Lee
  • 148 posts
  • Melbourne, Australia
Posted 10 April 2018 - 03:51 PM
Something with pin registration maybe?
I had an SR3 and 2, which both had pins but also have had bolex EBM and H16's which didn't and had comparably stable images.
#3 Jan Ruzicka
Jan Ruzicka
  • 10 posts
  • Planet Earth
Posted 11 April 2018 - 12:00 AM
Good to hear you had comparably stable images, that makes the bolex more desirable for me because of its compact size.
Any super16 cameras with pin registration as compact as a Bolex h16/SBM?
#4 Giray Izcan
Giray Izcan
  • 404 posts
Posted 11 April 2018 - 09:34 AM
You dont need a pin registration. Pin registration on 16 cameras isnt like on 35 where you have two pins to hold the film steady. The registration pin acts more like a stopper rather than full on registration like on 35 cameras. Aaton doesnt use registration pins but hast one of the best registration. As long as your camera is up to specs, the registration shouldnt really be an issue.
#5 Jan Ruzicka
Jan Ruzicka
  • 10 posts
  • Planet Earth
Posted 11 April 2018 - 12:31 PM
Thanks for your input, the Aaton a-minima sounds very tempting for its compact size, the only setback for me is that it would not take 100' daylight spools out of the box without re-spooling the film each time.
#6 Giray Izcan
Giray Izcan
  • 404 posts
Posted 11 April 2018 - 08:52 PM
Aaton a-minima is a fine camera but I would only use it as a b cam. The viewfinder doesnt rotate, loud - comparison to an txt prod or an sr3 and takes special film.
#7 Pavan Deep
Pavan Deep
  • 376 posts
  • UK
Posted 12 April 2018 - 02:38 AM
I think the Aaton Minima is a very good camera, its main drawback as you mention, is the special loads it needs, I haven't found the viewfinder or the noise an issue. A while ago someone mentioned that they had made a magazine for the Minima so that it can accept normal 100ft loads, I haven't seen it myself.
Pav
#8 Jan Ruzicka
Jan Ruzicka
  • 10 posts
  • Planet Earth
Posted 12 April 2018 - 03:55 PM
I definetly need a small form factor for traveling, the a-minima seems easier to handle and more ergonomic to shoot with than a bolex when out and about. Thanks for your input.
#9 Jan Ruzicka
Jan Ruzicka
  • 10 posts
  • Planet Earth
Posted 11 May 2018 - 06:14 PM
So,  I went the bolex route, a bolex SB converted to super 16mm bayonet mount and comes with a C-mount adapter. Now I need a compact zoom lens to go with it for traveling.
Any suggestions?, it needs to cover well the super 16 gate, no vignetting.
Thanks for your input!
