Best way to immitate soft moonlight (max 10kW)
#1 Nojus Drasutis
Nojus Drasutis
  • 66 posts
  • Lithuania
Posted 17 April 2018 - 11:01 AM
Hi, what's the best way to imitate a really soft moonlight with small budget. I'm able to have 2x5kW generator.
I don't need to cover a lot of space(3meters/10ft x 10meters/30ft), EXTERIOR, I need to use it as a fill just to get enough exposure for blacks.
I'm shooting on Kodak Vision 500 T, which has 250 ASA left.
The main light source will be a lot of fire torches - one for one actor. they give me enough exposure on the faces (f 4 - f2,8), so, as I said, I need the moonlight for filling and raising up the blacks.
I was recomended to use 4x Joker Bug 800 + Standart Lantern chmeras. I never used them. Do you think they would have enough output?
Thanks !
Edited by Nojus Drasutis, 17 April 2018 - 11:02 AM.
#2 aapo lettinen
aapo lettinen
  • 1188 posts
  • Finland
Posted 17 April 2018 - 03:37 PM
should be enough for such a small set and underexposed moonlight. if you need only one big soft source you can consider bouncing them all from a single or two (side by side) 12x12 for example. chimeras would be harder light but also more exposure for the blacks
  • 1
#3 Nojus Drasutis
Nojus Drasutis
  • 66 posts
  • Lithuania
Posted 17 April 2018 - 04:41 PM
Maybe then it would be better to use some Fresnel HMI's like 2x Arri M18, spot them into 12x12 and bring the whole thing farther away?
I worked mainly with tungsten so I'm not sure how much output this would give.
#4 Adam Frisch FSF
Adam Frisch FSF
  • 2053 posts
  • Los Angeles, USA
Posted 17 April 2018 - 07:20 PM
Skypanels
#5 Guy Holt
Guy Holt
  • 580 posts
  • Boston
Posted 17 April 2018 - 07:42 PM
Hi, what's the best way to imitate a really soft moonlight with small budget....I'm shooting on Kodak Vision 500 T, which has 250 ASA ....
If the torches set your exposure at f4 with a 250 ASA stock you will need more Foot Candles than you can get bouncing a couple of M18 into a 12x frame at a distance. You might look into renting an Airstar Gaffair 4k HMI balloon.
A modified 7500W Honda EU6500is generator and 60A Full Power Transformer/Distro powering 4kw HMI and 8kw Tungsten AirStar Balloons at an IATSE Local 481 Balloon Seminar.
It will be a lot easier to fly than a large 12x frame bounce, give you better results, and can be powered off a Honda EU7000 or EU6500 as we did for the IA training workshop pictured here.
Guy Holt, Gaffer
ScreenLight & Grip
Lighting Rental & Sales in Boston
Edited by Guy Holt, 17 April 2018 - 07:47 PM.
#6 timHealy
timHealy
  • 1291 posts
Posted 18 April 2018 - 01:50 PM
nevermind
Edited by timHealy, 18 April 2018 - 01:54 PM.
#7 Nojus Drasutis
Nojus Drasutis
  • 66 posts
  • Lithuania
Posted 21 April 2018 - 06:27 PM
Guys, Thanks for your answers.
Guy Holt, Gaffer
ScreenLight & Grip
Sadly, I live in Lithuania. As far as I'm aware of, we have only 2x Gaffair 1.2kW in rental houses.  I'd love to use this beast. Do you think few of 1.2 kW would be enough?
Skypanels
Yes, maybe, but they are quite a bit more expensive, aren't they?
Again, Thanks for everyone!
