Is there a reason tilt shift videos always seem to be time lapse?
tilt-shift tiltshift tilt shift
#1 Tim Immordino
Tim Immordino
  • 4 posts
Posted 23 April 2018 - 06:48 PM
Prepping for a short and have an idea to shoot the open in tilt shift, or tilt shift effect in post. I understand that whether you actually use a TS lens or do it in post, results are best with simple subjects (people, cars, trains) at a distance and from a high angle. All that's fine for my purposes... However, I don't want time lapse. Does the effect not translate in live action? Or is there some technical reason it can't be done? I can't seem to find much video (ok any) of non-time lapse tilt shift footage.
Still sussing our camera package, but budget is very low so we're likely shooting on SONY a7s if that makes a difference...
Any other technical advice is welcome.
Thanks in advance for your help!
#2 Dom Jaeger
Dom Jaeger
  • 1886 posts
  • Melbourne, Australia
Posted 24 April 2018 - 12:01 AM
No reason you can't shoot normal video, it's just a lens.
From your description it sounds like you're interested in the "miniature world" type shots with a narrow band of focus, but there are many more things you can do with shift/tilt lenses, including altering perspective lines and adjusting the plane of focus to increase the apparent depth of field. They're very versatile and interesting lenses to play around with, and certainly not limited to time-lapse. I suspect the miniature world videos you're seeing use time-lapse to accentuate the impression of a toy landscape, and people just copy what others have done.
Cinema has inumerable shots done with tilt/shift lenses, often to shift the focus plane in order to keep two subjects at different distances both in sharp focus. A movie like "The Diving Bell and the Butterfly" used them to great effect.
The archives here have some more info:
http://www.cinematog...showtopic=23899
http://www.cinematog...showtopic=46445
#3 Tim Immordino
Tim Immordino
  • 4 posts
Posted 25 April 2018 - 12:35 PM
Dom, this is super helpful... I suspected as much. Honestly I'll probably have to fake the effect in post (budget constraints), but I think your answer still probably applies.
Thanks especially for the additional info above -- Definitely going to look more deeply into tilt shift lenses...
Thanks again, great info.
Tim
#4 Jaron Berman
Jaron Berman
  • 199 posts
  • New York, NY
Posted 25 April 2018 - 10:10 PM
Tilt shift lenses allow you to achieve "movements" - a term pioneered in the world of large format film photography.  On a 4x5 or 8x10 camera with bellows, the lens itself is relatively simple and contains generally just an iris and shutter.  Focus is achieved by moving that optic closer and farther from the film plane.  But you can do more than just move it in/out - bellows allow you to rise/fall the lens parallel to the film plane or shift it sideways or swing it sideways or tilt it up/down - and bellows allow you to do all these things at once.  Or you can leave the lens in place and rise/fall/shift/swing/tilt the film plane itself.  The tilt/shift lens is a method to achieve some of these movements on cameras without bellows.
These lenses work because the optics cover an area much larger than the sensor/film size of the camera they're intended for.  To picture what a Tilt/shift lens is doing, imagine that the lens projects a circular image the size of a round paper plate.  Inside that paper plate is a 3x5 notecard which represents your sensor/film.  Sliding that paper plate around on top of the notecard you're choosing that portion of the projected image.  That's what's happening with a shift/rise/fall.
Imagine pointing your camera on a wide-angle lens at a tall building.  If you aim level, you'll likely cut off the top of the building.  If you tilt your entire camera up you'll frame it in, but you'll exaggerate the "keystoning" of the building or the appearance of the sides of the building angling together at the top.  An architectural photographer (or Stanley Kubrick for example) may not want those lines to converge and may prefer that door frames, corners etc all remain perfectly upright.  The power of the rise/fall movement is being able to keep the camera level and rise the lens itself upward to frame-in the top of the building without changing the geometry of the room.  Very cool.  Or conversely - you could "fall" the lens to trim your frame for headroom without tilting the camera down.  It's a cool and subtle effect.  Spin that on its side and do a horizontal shift, and now it's as though you're standing a bit farther to the side than you are.  Useful way to shoot into mirrors without seeing yourself.
Tilting is a different story and most of what you're seeing when people use TS/E lenses for effect is because of tilting the lens in relation to the focal plane.  The math behind tilting is called the Scheimpflug principle.  Basically your plane of focus is no longer parallel to the sensor/film, and you can choose what angle your plane of focus falls.  Meaning - you can shoot someone walking towards you from some distance away and if you choose their path and the plane correctly, you won't have to pull focus because they'll be sharp the whole time.  The rest of the scene may look crazy but they'll be sharp.  Or you could aim straight down a long road and have the entire road be in focus.
There's a lot more to TS/E lenses than just that "fake miniature" effect, and knowing that these tools exist can be super helpful for those few times when you're in a head-scratching situation.
  • 1
#5 Tim Immordino
Tim Immordino
  • 4 posts
Posted 03 May 2018 - 12:54 PM
Jaron - Sorry for the delay in responding, I've been crazy busy... This is great info and very helpful... Exactly the kind of knowledge I joined cinematography.com for. Thank you for sharing!
Also tagged with one or more of these keywords: tilt-shift, tiltshift, tilt shift
