What do these settings indicate? (DEDOLIGHT DLH4)
dedolight lighting dimmer settings help query
#1 Megan Bryan
Megan Bryan
  • 2 posts
  • England
Posted 01 May 2018 - 11:04 AM
Hi, I'm fairly new to this forum so hopefully, I'm writing this query in the right place.
For my dissertation, I completed a test using Dedolight DLH4's (The 3 head kit) and I used the dimmer switch to adjust the intensity of the light.
I was wondering what the dots represent on the dimmer switch?
I've attached an image below for reference. I was hoping to find a numerical value as so far my research has only found this indicating 'dimming from minimum to maximum'.
Any information or guesses are greatly appreciated and hopefully, someone can shed some light on this!!
Thank you.
#2 Adrian Sierkowski
  • 7505 posts
Posted 01 May 2018 - 11:17 AM
Well there's I think 16 notches, so 100% being top and 0% being bottom each notch is 6.25% so therefore the "dots" would be 0, 37% (ish, probably 25% visible) 68% ish (and that's probably 50% visivble) and then 100% That's what I'd assume. But really it won't be EXACT, it's just, as I often say "good enough for government work."
#3 JD Hartman
JD Hartman
  • 1801 posts
  • Edison, N.J. U.S.A.
Posted 01 May 2018 - 05:07 PM
Test the output with a lightmeter at various setting of the slider (min., max., in-between), interpolate the rest.
#4 Megan Bryan
Megan Bryan
  • 2 posts
  • England
Posted 02 May 2018 - 05:02 PM
Thank you both for your suggestions! Both are very helpful, thank you.
Also tagged with one or more of these keywords: dedolight, lighting, dimmer, settings, help, query
