Gelling/papering windows day for night
#1 Brandon Ruiz
Brandon Ruiz
  • 23 posts
Posted 01 May 2018 - 02:06 PM
I'm shooting a warehouse interior day for night on a music video and want to try gelling or papering windows warmer for a stylized look to suggest sodium vapor coming from outside. Tenting and lighting isn't really in the budget. Anyone have any luck with a material that looks good on windows DFN? I'm pretty sure a straight CTS or CTO gel on the windows won't give me the the contrast to suggest a night exterior. Maybe something like unbleached waxed paper would work?
#2 Frank Wylie
Frank Wylie
  • 132 posts
  • Culpeper, VA
Posted 01 May 2018 - 03:45 PM
Save yourself some heartache;  tent the windows and relight the panes with the proper gels if you can.
Shooting natural light with gels or paper will be a continuity nightmare as the sun shifts overhead.
If you are uncertain, just put some cheap butcher paper over the windows and run a timelapse test of the duration that would be your shoot.  I think you'll see the problems that might occur by trying to use natural light over an extended period.
#3 Adrian Sierkowski
  • 7505 posts
Posted 01 May 2018 - 04:07 PM
Another option would be to use 1000H  Vellum on the windows and then color correct it later on (or do a LUT in camera) to make it that nasty color. I'd realty TEST to see what gel you could use on your own lighting in order to give you a white reference (something blue-ish, probably).
Of course, if you don't completely black out the windows you'll still not have much contrast unless you're using HUGE units; so honestly your best bet would be to just black out all the windows and have the outside be "black" and then use lights on the inside.
