Slight gap between lens and mattbox ring?
#1 Ryan Constantino
Ryan Constantino
  • 43 posts
Posted 11 May 2018 - 12:37 AM
I just picked up a Zeiss LWZ2 which is a 114mm front and I have an Arri MB18 which comes with a filter ring with rubber donut that says it has a 114mm diameter. However there is the slightest gap between the ring and the lens. Here is a photo:
https://imgur.com/a/u9DhLMy
Is this normal? I would be concerned about a little bit of light getting in there. Any suggestions?
#2 Kyryll Sobolev
Kyryll Sobolev
  • 84 posts
  • Toronto
Posted 11 May 2018 - 08:06 AM
looks like the filter ring is missing a ring which sits on the inside of the rubber
like this, with the text printed on it - http://www.photocine...0-0-01-J0KL.jpg
otherwise yes, you wil have light leaks that will bounce off your filters and into the lens
Edited by Kyryll Sobolev, 11 May 2018 - 08:10 AM.
#3 Ryan Constantino
Ryan Constantino
  • 43 posts
Posted 11 May 2018 - 03:33 PM
Thanks for the reply. Yes you are correct I had to reach out to Arri for the part number. Appreciate the suggestion!
#4 James Malamatinas
James Malamatinas
  • 160 posts
  • 2nd Assistant Camera
Posted 12 May 2018 - 02:37 PM
Whilst youre waiting you can just use/make a neoprene donut to prevent any light coming through the gap. We often use them ever when we do have the correct sized rings as it can make life easier.
#5 Ryan Constantino
Ryan Constantino
  • 43 posts
Posted 12 May 2018 - 03:47 PM
Interesting, that's worth a shot in the meantime. Would I get it from the craft store do you think?
#6 Adrian Sierkowski
  • 7502 posts
Posted 12 May 2018 - 03:59 PM
https://www.bhphotov...roMatteBox.html
easier and cheap enough to order.
