H16 Reflex Finder Mask Alignment
#1 Nomad Zamani
Nomad Zamani
  • Scotland
Posted 24 May 2018 - 12:17 PM
I recently acquired an original H16 Reflex and have a question about the alignment of the mask on the top of the prism.
When I look through the reflex finder, I see the outline of the finder itself, with the mask on the prism markedly offset to one side (see attached photo). If I swing the prism out, the mask outline disappears and I see the whole area with the hard black outline around it.
Am I right in thinking that this is out of alignment, or is it normal?
#2 Phil Soheili
Phil Soheili
  • 52 posts
  • Milan, Italy
Posted 24 May 2018 - 01:07 PM
There is - right in front of the prism - a gelatine (filter) holder. Just check if it is fully inserted and / or if it actually carries a mask or sth like that.
best,
Phil
#3 Nomad Zamani
Nomad Zamani
  • Scotland
Posted 24 May 2018 - 01:11 PM
Still get the same thing with the filter holder removed.
#4 Simon Wyss
Simon Wyss
  • 1502 posts
  • Basel, Switzerland
Posted 24 May 2018 - 01:33 PM
Neither the prism cache nor a filter slide is misaligned. That thing is the front prism in the finder chute decentred.
#5 Nomad Zamani
Nomad Zamani
  • Scotland
Posted 24 May 2018 - 02:06 PM
The grey outline is the mask. When I slacken the one screw that's accessible, I can move the mask around a little. When I do that, its position changes in the finder. I'm not saying something isn't decentred in the finder's optical path, however. The issue with the mask is that the screw goes into a slot that allows it to move front to back (up/down in the finder), but there's very little scope to move it left/right - the side of the slot hits the screw. The attached shows it after some adjustment - moved down and left a little when viewed through the finder, enough to get the missing rounded corners into view.
I did take the plate off that covers the parallelogram prism and had a look. There were packers at the top and on the right-hand sloping face (viewed from the front), and it all felt pretty solid. I could have a closer look to see if it might have become decentred, although I don't think I want to take it out unless I have something suitable to use as replacement packers (I suspect the original ones will disintegrate).
#6 Dom Jaeger
Dom Jaeger
  • 1745 posts
  • Melbourne, Australia
Posted 24 May 2018 - 03:00 PM
The prism at the end of the viewfinder tube should have 3 adjustments, you need a slotted driver (or a small tube filed to have to prongs) to turn the nuts and some acetone to dissolve the paint that is often sealing the nuts in place. I use an old viewfinder cover plate with the front part cut off so I can adjust while looking through the finder, and it's hard to see without the cover on.
