Dimmig Leds with board vs built in dimmers
Led dimmer
#1 Scott Imler
Scott Imler
  • 49 posts
Posted 01 June 2018 - 02:38 AM
Hi
We have a number of Led Panels that all have built in dimmers. We are rigging them into a grid thats 12 feet above our heads so we wanted to control/dim them from a lighting board and /or with some hand squeezers. The plan is to place the built in dimmers that are on the lights at 100% and then dim remotely from the ground.Any reason why this would not work. Was curious if they will flicker or possibly damage the panels in any way?
Thanks guys.
#2 Phil Rhodes
  • 12194 posts
Posted 01 June 2018 - 03:29 AM
You can't plug (most) LED panels into dimmers; it doesn't work like that. If you want to dim LEDs remotely you'll need to use types with DMX controls and wire that back to the board.
#3 Scott Imler
Scott Imler
  • 49 posts
Posted 01 June 2018 - 11:14 AM
Ya we have that capability was just curious if a hand squeezer would work as well.Sounds like it won't. Thanks Phil
#4 Phil Rhodes
  • 12194 posts
Posted 01 June 2018 - 12:33 PM
In theory there is at least one type of LED which will do that. A company called Visionsmith makes a drop-in LED replacement for fresnels which is designed to read the interrupted waveform created by a triac dimmer and dim the light accordingly. I can't see looking around for those just to solve a problem like this, though.
#5 Adrian Sierkowski
  • 7394 posts
Posted 02 June 2018 - 01:26 AM
A few of the LED tubes, Quasar and Sourcemaker for sure, allow for this; though honestly not sure on the others.
