Strange light leak? CP16
cp16 light leak 16mm
#1 Philip Kral
Philip Kral
  • 91 posts
Posted 06 June 2018 - 12:13 AM
Last summer I pulled my ultra 16 modified CP16 out of storage to use as a "b" cam and a good chunk of the footage came back with what appears to be a light leak shown here:
    Does anyone have any idea where it's coming from? It's an old cp16 with the dogleg lens. I can't seem to figure out where the leak could of come from. The camera is put together pretty tight. I noticed it didn't show up all the time, it slowly reappears within zooms. I'm wondering since this was converted to ultra 16 that perhaps it's leaking out side the parameters of the shutter. But I've used this camera before and this is the first time i've seen this.
      My second guess is that the cp16-A has what is essentially a C mount thread hidden under the "cup" that the dogleg lens is attached too, this was a tad loose and I had to tighten it later. Is it possible light could have leaked from there?
      The light is leaking from the bottom left of my camera obviously but I'd be damned if I knew where it was. It almost feels like it's coming from the lens itself. I don't think it's leaking from the body or where the magazine attaches because the leak would look different. Usually I'd shine a light through something and looks for leaks but I'm getting nothing..... Any ideas?
#2 Tyler Purcell
Tyler Purcell
  • 4135 posts
Posted 06 June 2018 - 01:43 AM
It's a fixed beam of light, so I'd make the assumption it was coming from the lens. My guess is, as you zoom the lens, there is some sort of gap being create that you aren't seeing that's allowing bright sun to get through. It could also be the lens mount as you discussed, but it would have to be somewhere in the lens itself for it to be so focused.
#3 Dom Jaeger
Dom Jaeger
  • 1745 posts
  • Melbourne, Australia
Posted 06 June 2018 - 04:27 PM
If it's a reflex zoom but you were using the camera viewfinder, did you cover the zoom eyepiece while filming?
