Reverse Effect Photography
#1 KKB22
KKB22
  • 13 posts
Posted 13 July 2005 - 01:11 AM
I want my subject that I will be filmming to move in reverse, and I really, really don't want the video strobing effect that is often created when creating these effects in post. I've noticed that cameras like the Arri LT and others of that sort can film at reverse speeds. Does one load the film into the take up side of the magazine expecting it to run to the feed side? If this isn't how it is done, does one film the subject normally then assemble the negative frame by frame in reverse? Or is there some other process entirely different to what I am thinking?
Cheers :D
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 13 July 2005 - 02:09 AM
Cheers  :D
<{POST_SNAPBACK}>
Many film cameras will run backwards. In the past with a Mitchell I alwasy used to just run the film from the take up side to the feed side. However the Keycode will be wrong (and possibly the take up motors going the wrong way) .So you have to run the film forwards first with a lens cap on, then run the camera backwards!
Cheers
Stephen Williams Lighting Cameraman
www.stephenw.com
#3 Sam Wells
Sam Wells
  • 1751 posts
Posted 13 July 2005 - 10:22 AM
As Stephen said.
But I don't know what you mean exactly by the 'strobing' effect in post.
If you don't do a speed change and simply run a shot in reverse in digital post or did it on an optical printer it looks the same as if you shot it in reverse.
-Sam
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 13 July 2005 - 10:34 AM
-Sam
<{POST_SNAPBACK}>
I guess he means when the fields are reversed!
Stephen
#5 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 13 July 2005 - 03:53 PM
Stephen
<{POST_SNAPBACK}>
and if the reverse speed is done after the film has been transferred to tape, non 1 to 1 reverse speeds can create field resolution, which is half the resolution versus frame resolution.
#6 KKB22
KKB22
  • 13 posts
Posted 18 July 2005 - 01:25 AM
THANKS!! Looks like I'm going with the most affordable camera I can rent that will film in reverse.
Cheers
:D
#7 jon w
jon w
  • 28 posts
  • Vancouver
Posted 18 July 2005 - 03:16 PM
i read a book a few years ago called "everything i want to know about filmmaking, i learnt from the toxic avenger". it was all about the low budget techniques making troma movies. i remember it saying that for reverse action (before computer, and i guess without the budget for a camera that runs in reverse), they would shoot the shot with the camera upside down, then flip the actual negative upside down, resulting in backwards / rightside up footage. makes sence in my head, but i think the shot would be a bit out of focus.
