Stroboscope / shutter issues
#1 Edgar Nyari
Edgar Nyari
  • 91 posts
Posted 08 August 2018 - 09:00 AM
Hi everyone,
I did some tests with a stroboscope light for an upcoming shoot, and found it extremely difficult to replicate a strobing light effect on film due to shutter and stroboscope sync issues. The perfect solution would be to use some sort of camera-strobe synchronization, which is out of the question. The camera is a 35mm film camera, and it's impossible to sync it in any way with the device I'm using.
Is there a set of "magic" strobe frequencies that work best with 180 degree shutter on 24 fps, to give a nice flickering effect without too much skipping?
Considering this is my only light source in this scene, and total darkness should be between flashes, should I perhaps shoot the scene in full light, then just edit in blank frames at any desired frequency?
Is this ever done in editing?
thanks
Edgar
#2 timHealy
timHealy
  • 1290 posts
Posted 01 September 2018 - 06:49 PM
If I recall correctly, a company called Unilux in New Jersey once made a syncable strobe. It was mostly used to shorten the exposure of every frame with the strobe so juice squeezed out of an orange or water coming out of a shower head was captures in crystal clear blobs instead of blurry streams with normal shutter rates. Perhaps they can help you.
I haven't seen these lights in years though.
best
Tim
