What does the "AR" of Angenieux AR lenses stand for?
Angenieux
10 replies to this topic
#1 Larry Miles
Larry Miles
  • 36 posts
Posted 12 August 2018 - 09:24 AM
I apologize if this has been covered previously but if it has I could not find the thread.
What does the "AR" of Angenieux AR lenses refer to, and which Angenieux lenses are AR? Specifically, is the Angenieux 12-240 an AR lens? Thank you.
  • 20160 posts
Posted 12 August 2018 - 09:55 AM
Maybe the designer was a pirate?
  • 2
#3 Larry Miles
Larry Miles
  • 36 posts
Posted 12 August 2018 - 10:13 AM
Thank you, David, I hadn't considered that.
The specific reason why I'm asking is that I recently purchased a Birns and Sawyer Angenieux AR 2x telezoom with an Arri standard mount. It in fact does fit into an Arri standard adapter but my Angenieux 17.5-70mm lens, with an Arri std mount, does not fit into its other side.
#4 Macks Fiiod
Macks Fiiod
  • 1472 posts
  • Og from DC, Now in NJ
Posted 12 August 2018 - 01:12 PM
"Shots poppin' out the AR"
-Robert Shmurda
Or in your case, into the AR.
Given the telezoom thing, maybe it could mean "aberration reduction"?
#5 Larry Miles
Larry Miles
  • 36 posts
Posted 12 August 2018 - 05:23 PM
Does it simply mean Arri? I believe the AR designation on Kern lenses refers to the coating.
Does anyone know if an Angenieux 12-240 Arri std mount will fit into the telezoom? If you believe it will, do you know why my Angenieux 17.5-70 Arri std mount does not?
#6 Dom Jaeger
Dom Jaeger
  • 1774 posts
  • Melbourne, Australia
Posted 12 August 2018 - 09:03 PM
Can you post photos?
I don't know about an AR code with Angenieux. If it's on an Arri mount 2x extender maybe it refers to "Arri", or maybe it means "Anti-Reflective" like on Kern lenses, to describe the coating. Is the extender made by Angenieux? Angenieux used lots of codes to refer to the lens design (B, R, P, L, Y etc) but I've never heard of an AR one.
Some lenses won't fit on extenders because the optics interfere - the rear element of the lens needs to be recessed into the mount by a certain amount - so check that your zoom clears the extender optics.
#7 Larry Miles
Larry Miles
  • 36 posts
Posted 12 August 2018 - 10:08 PM
Thank you, Dom. Attached are the photos.1502.jpg 1500.jpg 1503.jpg 1504.jpg 1505.jpg s-l400.jpg s-l401.jpg s-l402.jpg
#8 Dom Jaeger
Dom Jaeger
  • 1774 posts
Posted 13 August 2018 - 01:53 AM
OK, well it looks to me like the Telezoom extender has what's called a universal mount which attaches to the back of older 35mm Angenieux zooms like the 25-250. The extender is missing the lock-ring that would normally sit behind that front flange and lock the unit to the back of the zoom. What you did was remove the Arri mount and replace it with the extender.
This is a newer version from a Cooke 18-100:
It's possible "Angenieux AR" refers to the first generation 25-250, before the HP and HR.
So I don't think it would work with that 12-240 unfortunately.
Though I'm curious what the O-L lock ring in the middle of the extender does?
#9 Phil Rhodes
  • 12274 posts
Posted 13 August 2018 - 04:13 AM
Hazarding a guess here, but is it the macro adjustment, as on an ENG lens, or just a way of adjusting back focus (which is much the same thing?)
#10 Dom Jaeger
Dom Jaeger
  • 1774 posts
Posted 14 August 2018 - 02:13 AM
I've never seen a macro or back-focus adjustment ring on a cine focal extender..  more likely to be a lock ring (O - open, L - lock). Maybe it unscrews to allow different mounts to be fitted to the back?
#11 Larry Miles
Larry Miles
  • 36 posts
Posted 16 August 2018 - 09:33 AM
The O-L refers to Open/Lock. The front piece, the one on top of the telezoom in the fifth picture that prevented an Arri Standard mount lens from being fitted into it, is removable. Once removed, my Angenieux 17.5-70 with an Arri Standard mount fit, however the O/L lock did not keep it in place. The removable front piece has a tab that fits into a slot in the telezoom which allows it to be locked. Perhaps the Angenieux AR 25-250 has the same tab?
Also, although it fit, the 17.5-70 is not in focus when used with the telezoom. I have yet to experiment with sliding it so that it's not fully pushed in, but I'm doubtful that will work.
