Frame Rate in Premiere
7 replies to this topic
#1 nerv Liutenant
nerv Liutenant
Posted 20 July 2005 - 03:21 PM
I'll be shooting my next feature with th dvx100a, in 24p advanced mode. My question is: when i capture in premiere, should I set the capture video to exactly 24fps capture or 23.97 capture? i dont want discrepencies in post, so I thought I'd just ask if anyone has had experience with it.
#2 Joshua Provost
Joshua Provost
  • 71 posts
Posted 20 July 2005 - 03:55 PM
<{POST_SNAPBACK}>
Remeber, it's 24p embedded in NTSC 29.97 video. Premiere Pro 1.5 has a project preset called Panasonic 24p for this. Use that preset, and it should auto-detect how to capture the video, and drop the extra frame on the fly when you place the footage into a timeline. It will also default to output 24pA when you Export/Movie.
#3 Phil Rhodes
  • 12175 posts
Posted 20 July 2005 - 04:01 PM
...although that probably isn't what you want if you're exporting a 24p project for NTSC viewing, in which case conventional 3:2 pulldown will look smoother.
Phil
#4 Joshua Provost
Joshua Provost
  • 71 posts
Posted 20 July 2005 - 05:23 PM
Phil
<{POST_SNAPBACK}>
Or, output an uncompressed AVI at 24p (23.976, actually) for your final output, and encode that to a 24p DVD, for best results.
#5 nerv Liutenant
nerv Liutenant
Posted 20 July 2005 - 07:08 PM
What if i happen to be working in premiere 6.5 without that particular preset?
#6 Phil Rhodes
  • 12175 posts
Posted 21 July 2005 - 04:36 PM
Then you'll have a normal NTSC timeline, and it should cut fine, but you'll need to look into some external convertor to get your 24p stream out of your exported 24pA movie. An AVIsynth script could do it.
Phil
#7 Joshua Provost
Joshua Provost
  • 71 posts
Posted 21 July 2005 - 05:31 PM
<{POST_SNAPBACK}>
If you are already in the midst of your project in a normal NTSC 29.97 timeline, you're in big trouble, since your 24pA drop-frames are likely mixed up all over the place. You won't be able to remove them later if you've already made some cuts. You probably need to ditch the project and start a new one with the right settings. :(
#8 Phil Rhodes
  • 12175 posts
Posted 21 July 2005 - 05:48 PM
Well, don't panic quite yet - there's some very clever ITK filters out there for things like AVIsynth and Virtualdub which will look at frames intelligently and give you a 24p stream out of 3:2 or 24pA.
Phil
