Help with decision: Arri 150 vs. Pepper 100
25 replies to this topic
#1 CJ Biddle
CJ Biddle
  • 4 posts
  • NY & MA
Posted 28 July 2005 - 09:29 AM
Hello,
I am adding a few things to my (small) kit. I shoot both film & video and need two or three little fresnels. I've used pepper 100's and Arri 150's a few times and like the size of the peppers.
However, I would like input from others as to the difference in quality of light from these fresnels since they have different reflectors and lenses.
Is there a general preference?
Is the throw that different?
(As an aside, dedo's are too pricey for me right now.)
Thank you in advance for your input,
CJ
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 28 July 2005 - 10:30 AM
Hello,
<{POST_SNAPBACK}>
I would get dedo's. The bulbs last for a year or more and dont break if you drop them! In 2 years use the dedo's will work out far cheaper IMHO.
Stephen Williams DP
www.stephenw.com
#3 Bob Hayes
Bob Hayes
  • 1087 posts
  • Culver City, California
Posted 28 July 2005 - 10:32 AM
Between Arri and Pepper I'd choose the Arri. Peppers get too hot and don't focus well.
#4 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 28 July 2005 - 10:51 AM
Peppers' wiring shorts out and works loose often. I think Arris are a little better built. Dedo's might be better but cost a LOT more. Arri 150- $230, Dedo 150w- $670. You can buy many bulbs for $450.
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 29 July 2005 - 01:57 AM
<{POST_SNAPBACK}>
You can't really compare the Dedo 150 with the Arri 150, the dedo is FAR brighter and much more flexable. You should go down to your local rental house and compare them. With the prices I pay in Switzerland for bulbs the dedo is 'FREE' after 2/3 years of use.
For $450 you can get around 15 bulbs for a pepper. You will still be on your first bulb with the Dedolight!
Stephen
#6 Robert C. FIsher
Robert C. FIsher
  • 8 posts
  • Electrician
Posted 29 July 2005 - 02:04 AM
The last time I priced Dedo heads (just head no transformer or built in supply) they were around $200-250, that's just the head. You can easily make a 12v or 24v power supply, if you are handy with tools, using electronic transformers for MR-16 fixtures. The 100 watt bulb is a 12v and the 150 watt is 24v. But if you are set on Arri or LTM Pepper I would go with the Arri also, they are much better built. But if you want a great light go with the Dedo.
#7 CJ Biddle
CJ Biddle
  • 4 posts
  • NY &amp; MA
Posted 30 July 2005 - 09:09 AM
Thanks, everyone. Great advice, good points.
If I get the Dedo's right now, that means no Kino Diva 400, which is on my need-right-now list. I'm going to get an arri 150 right now and stick to renting the dedo's for the time being.
But after the fine points put forward here, I'll set aside some cash (or hit some schoolkids up for their lunch money) and buy one or two dedo's down the road.
Thanks again,
CJ
Making things happen with lunch money budgets
#8 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 30 July 2005 - 11:51 AM
Stephen
<{POST_SNAPBACK}>
How bright would you say the Dedo light is and how is it more flexible? I see how it would take less power to operate, but are there other advantages? Here's a website where you can order 100w bulbs for $12.75, which is roughly 30 bulbs for $450.
#9 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 30 July 2005 - 01:13 PM
<{POST_SNAPBACK}>
Compare the photometric date of a dedo then look at the other lamps. They also have a much greater range flood to spot. As for the bulbs how long will those 30 bulbs burn? The bulbs for the dedolight run to 3000 hours each, are not delicate, you can drop a burning light and the bulb is not damaged. I used to think I could not afford dedo's that was 10 years ago. Now I have got rid of the other small lamps and have saved a fortune!
Stephen
#10 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 30 July 2005 - 01:36 PM
Stephen
<{POST_SNAPBACK}>
I might look into getting one. I like that 1K softlight with the built in speedring. What models do you use? The $2000 models are out of my price range, but $700 for the softlight sounds reasonable.
#11 Robert Edge
Robert Edge
  • 401 posts
Posted 30 July 2005 - 04:58 PM
I have two Dedo DLH4 heads, with a power supply for each, that take 100w (12v) and 250w (24v) lamps. I also have a projection attachment. Not having used the Arri and Pepper lights, I can't draw a comparison, but I am very happy with the Dedos, and the photometrics, at least on paper, are very attractive. The Dedos are also very well built.
Lately, I have been thinking about buying a 650w Dedo. Although one might think that the design is the same, the published photometrics, in comparison with those of competitors, are not as interesting as those published for the DLH4. If anyone knows why the photometrics are different, or has experience with the 650w, I'd appreciate comments.
#12 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 31 July 2005 - 05:13 AM
<{POST_SNAPBACK}>
I bought some 650's when they first came out. The original ones had an issue with the barn doors falling off! The light output is nearer a 1K. Fully spotted the light output exceeds that of a 5K fully spotted! Very versitile, but the bulbs don't last for ever so there are no cost advantages here. The 400w HMI version is interesting too. Worth a look!
Stephen
#13 Robert Edge
Robert Edge
  • 401 posts
Posted 31 July 2005 - 09:48 AM
Thanks Stephen. The 650 is now on my shopping list. The 400 HMI does sound good, but with a price to match. Maybe if I swallow hard :)
#14 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 31 July 2005 - 10:45 AM
<{POST_SNAPBACK}>
I think its much better to rent the expensive stuff like the 400 HMI!
Stephen
#15 Robert Edge
Robert Edge
  • 401 posts
Posted 31 July 2005 - 07:45 PM
Stephen
<{POST_SNAPBACK}>
I priced the 400 HMI today at a shop in New York that is open Sundays. Yes, renting one might be more commensurate with my pocketbook.
#16 Chris Keth
Posted 04 August 2005 - 11:01 AM
Between the Arri and Pepper (I'm with the "get the dedo" crowd, but I'll give my either/or opinion) definately get the Arri. While I don't own either, I work in the equipment cage for my university program and we can usually see what is tough and what is not, since some people don't take the best care of our equipment. The peppers are always on the down-equipment list. The wiring seems to come lose, short, etc. monthly. The arris are tough as nails.
#17 Brian Wells
Brian Wells
  • 438 posts
Posted 01 January 2006 - 11:59 PM
Thanks to the wonderful advice given here (especially by Stephen W., you are very persuasive!) I'm planning to buy one of the 150W Dedo's. I'm curious to hear about how to "easily make a 24v power supply" and save myself some currency! Is it worth it?
#18 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 02 January 2006 - 07:37 AM
Brian,
Dedo have recently released a 24v dimmer for the 150w lights. I think its worth the money. I have seen Kaylights on E-Bay selling some new kits and single lights, at discounted prices.
I have modified domestic power supplies for 12v Dedo's, its worth it for getting started but in the end you will want to upgrade.
Cheers
Stephen
#19 Brian Wells
Brian Wells
  • 438 posts
Posted 02 January 2006 - 03:29 PM
Thanks Stephen. Long term I would like to own three Dedo 150's and the 3-light transformer. So, that's why I thought about going "cheap" initially with a domestic transformer, just to get my foot in the door. Then, buy the additional heads and transformer when I need them.
This isn't an easy decision because the resale value of a single transformer probably isn't very high.
Thanks for your advice.
#20 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 02 January 2006 - 04:04 PM
I just bought a 1 year old 3 light transformer from a Dedo Dealer for about $340. It had been used for an exibition. I guess you will end up with a 4th light!
Stephen
