Rebuilt Lenses
#1 Robert Edge
Robert Edge
  • 401 posts
Posted 29 July 2005 - 07:07 AM
What is a rebuilt lens? What has been done to it, or should have been done, and how does a rebuild compare to a new lens?
#2 andrewbuchanan
andrewbuchanan
  • 216 posts
  • Chapel Hill, North Carolina
Posted 29 July 2005 - 07:35 AM
When I have seen this term used it usually refers to a non-cine type of lens like a Nikkor or Leica that has been put into a new housing with proper marking and mechanics for cinematography use. Often a BNCR or PL mount is added and integrated iris and focus gears are installed. Sometimes it refers to a older cine lens that has been updated with the same stuff. Don't think of it like a rebuilt engine (something that is worn-out and needs repair), rather think of the rebuild referring to modification. I have a rebuilt set of Cooke Speed Panchros and some Samcine Nikons. They look like they were made with new lenses.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 29 July 2005 - 07:40 AM
<{POST_SNAPBACK}>
If your thinking of selling the Cooke Speed Pancros let me know!
Stephen Williams
www.stephenw.com
#4 Robert Edge
Robert Edge
  • 401 posts
Posted 29 July 2005 - 08:22 AM
Understanding a rebuild in this way, I assume that no work is done to replace lens elements or correct for scratches, etc.
How hard it is to find older lenses that are not showing signs of use that impair them optically or mechanically?
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 29 July 2005 - 08:37 AM
<{POST_SNAPBACK}>
Centuary rebuild some new still camera zoom lenses. The final cost is arroud $17000! Many times the cost of the original lens. The rebuilt Cookes have modern style & well marked barrels. There would be no point in rebuilding a lens with damaged optics. Front and rear elements will often be replaced and modern coatings applied.
Old Cooke/Zeiss lenses are fine if they have been looked after, just don't compare the mechanical design or optical performance with the lateat glass.
Stephen
#6 andrewbuchanan
andrewbuchanan
  • 216 posts
Posted 29 July 2005 - 09:09 AM
<{POST_SNAPBACK}>
Stephen, tried to PM you, but I'm not sure it went through. I'm on a real POS computer today. Let me know if you got it.
