Bad film from the lab
13 replies to this topic
#1 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 29 July 2005 - 02:03 PM
I just got back a batch of film from the lab. I had the negative transferred to mini-dv. One roll however was pulsing with bad frames every second or so. The frames looked extremely grainy. Could this be a light leak? I find this strange because only one of my rolls came back like this. The rest were fine. I was shooting with an Rex-5 Bolex. I thougt maybe the filter holder wasn't in or something but I thought that would give me a constant washout on all the frames not this strobing/pulsing effect. Could this have been a lab issue?
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 29 July 2005 - 02:22 PM
<{POST_SNAPBACK}>
Could you post some bad frames?
Stephen
#3 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 30 July 2005 - 04:45 PM
Here they are. The first is alright the second has a light haze over it. I pulled these from the mini-dv tape so it's a little tough to see. Where do you think this might have occurred?
#4 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 30 July 2005 - 04:48 PM
Stephen
<{POST_SNAPBACK}>
#5 David Mullen ASC
  • 20068 posts
Posted 30 July 2005 - 05:42 PM
Reminds me of some X-ray fogging that I got on some recan stock...
#6 Richard Boddington
Richard Boddington
  • 5508 posts
Posted 30 July 2005 - 06:21 PM
When you say transfered to Mini DV, do you mean you supervised the transfer and colour correction of the neg to tape? Or did you just hand it off to them and let them do it?
Did they use any noise reduction?
Why did you go to Mini DV and not D-beta?
Also, what ASA film is that 7218? 500T in 16mm is going to have some grain, that's for sure, and looks like you're in a low light situation there.
R,
#7 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 30 July 2005 - 08:53 PM
We had a similar problem with a Bolex and it was caused by shutter bounce. But it was pretty much throughout the rolls we shot. It looked much more noticeable on some than on others. I hear it is a pretty common issue with Bolexes.
-Tim
#8 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 01 August 2005 - 06:13 PM
Almost certainly the lab would have processed all your rolls together. So it's very unlikely that one roll would be affected differently from the others.
Is the pulsing clear enough to tell if the rate (you say about one per second) varies throughout the roll? Things like X-ray fog (I'm with David, I'll have my money on that) happen when the film is in a roll. If the pulsing gets faster towads the end of the roll, then you have had a problem before exposure. If the pulsing starts fast and gets slower, then it happened after exposure and before processing. If it's regular, then it's not roll-based, and could be a camera problem - but it's hard to imagine what.
One second on 16mm film is about 7 1/4 inches. That's 2 1/4 inch diameter on the roll.
#9 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 02 August 2005 - 10:43 PM
Mild x-ray fogging will increase granularity, and can have a convolution repeat if one side of the roll is nearer the x-ray source. Likewise, if one side of the roll gets hot by being near a heat source or in the hot sun for a day, you could see a convolution repeat.
Short-ends and recans have more risk of having been stored improperly, and the grain increase caused by heat or radiation can sometimes be missed in simple clip testing.
#10 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 03 August 2005 - 08:45 AM
I'll have to look at the footage more closely. I see to remember it being about the same through the entire roll.
I haven't been near anything that would produce x-rays (that I know of).
What is shutter bounce? Does the shutter on the Bolex stick?
This is home movie footage that I shot last summer. After the wedding I put the roll in my refrigerator for safe keeping.
Would a light leak be more consistent? If I did not have the filter in all the way could that have caused this?
#11 Sam Wells
Sam Wells
  • 1751 posts
Posted 03 August 2005 - 08:54 AM
The filter clip not in all the way or missing would show fogging at the edge of the frame.
I don't see any streaking that I'd expect to with shutter mistiming.
Has the lab looked at the camera negative ?
-Sam
#12 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 03 August 2005 - 10:06 AM
No, the lab has not. I wanted to know what I am talking about before I talked to them.
Thanks!
#13 jeremy edge
jeremy edge
Posted 04 August 2005 - 05:19 PM
Thanks!
<{POST_SNAPBACK}>
Just curious ,what film stock was this?
#14 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 11 August 2005 - 09:28 AM
This was shot with 500T Vision film.
