85C filter for Ektachrome 64...
7 replies to this topic
#1 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 04 August 2005 - 02:16 AM
I have an 85C filter. I think I'll use it for my Ektachrome 64 test. Any reasons I shouldn't try it?
Posted 04 August 2005 - 02:36 AM
85A corrects 5500K to 3400K
85B corrects 5500K to 3200K
85C corrects 5500K to 3800K
So you will get a cooler daylight effect if you substitute the 85B with an 85C for a 3200K balanced stock.
#3 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 04 August 2005 - 03:50 AM
<{POST_SNAPBACK}>
Oops, looks like I don't know my 85 "a,b,c's" Or should I say, I don't know my 85 "c,a,b's". I didn't realize the 85B had more correction within it than an 85C.
What if I want to correct from 5600K to 3000K? Any one filter available for that?
#4 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 04 August 2005 - 05:36 AM
<{POST_SNAPBACK}>
Filter information on the Kodak website:
http://www.kodak.com....4.9.6.26&lc=en
http://www.kodak.com...onversion.shtml
http://www.kodak.com...balancing.shtml
http://www.kodak.com...t/h2/temp.shtml
#5 David Mullen ASC
Posted 04 August 2005 - 11:26 AM
<{POST_SNAPBACK}>
Either you'd have to add one of the 81 series to an 85 filter (like combine an 81A or 81B to an 85B) to further correct 5500K to 3000K, or experiment with using Coral filters and find one that is heavy enough, like a Coral 5 or higher. But you won't get quite the correct spectral response with Corals nor do they have any UV component built into them. So for reversal and direct projection, you'd have to shoot tests to determine the correct Coral filter.
MIRED for 5500K is 181.5 (divide 1,000,000 by 5500K), for 3200K is 312.5, and for 3000K is 333.3. So to shift 5500K to 3200K, you'd need a filter with a MIRED value of 312.5 - 181.5 = 131. To shift 5500K to 3000K, you'd need +152.
The 85B filter has a MIRED shift value of +131. So you'd need to add a filter with a shift value of +21. The 81A is +18, which is close enough.
http://www.ayton.id....colour_temp.htm
http://www.cinematog...oralFilters.htm
http://www.kodak.com...ltration4.jhtml
The Tiffen Decamired filters I don't believe go any higher than 12 (or a shift of +120).
#6 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 05 August 2005 - 03:43 AM
Thanks for the links John and David.
I was happy to see that a Skylight 1A helps remove blue, I didn't see it's mired shift listed, any idea what it might be?
Maybe an 85N (edit note, oops, ment 85B) and a skylight 1A is the way to go.
#7 David Mullen ASC
Posted 05 August 2005 - 03:51 AM
Maybe an 85N and a skylight 1A is the way to go.
<{POST_SNAPBACK}>
I think it's +10, but I have no idea what an 85N filter is.
#8 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 05 August 2005 - 02:46 PM
<{POST_SNAPBACK}>
Oops, meant an 85 B (the two keys are right next to each other on the keyboard.)
