35mm A/B rolls for telecine & interlock
#1 Timothy Gassen
Timothy Gassen
  • 11 posts
Posted 05 August 2005 - 04:42 PM
I have a couple unusual telecine needs & questions:
I have 20-year old cut 35mm negative A/B rolls. I once had a 35mm print, but it is missing (along with the timing sheets from the A/B rolls). So I was wondering if I can have the A/B rolls transferred to video? I have heard that, unlike an optical printer which the rolls were designed for, the traditional telecine won't transfer the cut negs smoothly. True?
I don't want to have to strike another print just to transfer to video, and I don't have the timing sheets for fades/dissolves anyway!
Also, I'd like to transfer some original fullcoat mag track in interlcok for better sound quality. Of original material, all I found was a 16mm fullcoat mix (though I do have the separate 35mm optical track)!
I also want to transfer some positive 16m prints along with their mag track in interlock -- any telecine recommendation for the west coast/ LA?
Thanks for any help! :)
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 06 August 2005 - 06:11 AM
<{POST_SNAPBACK}>
Telecine's will jump slightly at a neg join. 20+ years ago all news was shoot on reversal and telecined live with joins. As the material is A/B cut you may be lucky in that the handles on each scene will be long enough, so as not to be a problem. You will have to try it out!
Stephen Williams Lighting Cameraman
www.stephenw.om
#3 Dirk DeJonghe
Dirk DeJonghe
  • 612 posts
  • Kortrijk,Belgium
Posted 07 August 2005 - 02:54 AM
A worse problem might be that the negative may be notched. A small shape may be cut out on the side of the film to trigger the scene-to-scene correction on the printer. This practice was later (mid 1970'ies) replaced by metallic foil patches and still later (1980'ies) with FCC ( computerized frame count cueing). When this notch passes the telecine gate it will give a noticeable sideways jump.
Easiest but not cheapest would be to strike a low contrast 35mm print and transfer this to video. You could even do a separate print from the A and B-roll, transfer to video and make the final color correction and dissolves on a digital color grading system such as Baselight.
