"Normal" shutter speed for 30p?
7 replies to this topic
#1 Peter J DeCrescenzo
Peter J DeCrescenzo
  • 620 posts
  • Portland, OR, USA www.peterdv.com Blog: http://herefortheweather.wordpress.com/
Posted 06 August 2005 - 01:01 AM
If it's true the "normal" shutter speed for 24p is 1/48 sec., then is the normal shutter speed for 30p 1/60 sec.?
- Peter DeCrescenzo
  • 20069 posts
Posted 06 August 2005 - 01:31 AM
- Peter DeCrescenzo
<{POST_SNAPBACK}>
If you're trying to simulate a 180 degree shutter angle in a film camera, yes.
#3 Peter J DeCrescenzo
Peter J DeCrescenzo
  • 620 posts
Posted 06 August 2005 - 01:50 AM
Thanks, David, and good evening!
- Peter
#4 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 06 August 2005 - 03:40 AM
- Peter DeCrescenzo
<{POST_SNAPBACK}>
It's the default when the shutter is in the "off" position, as well.
(It's 4:30am and I gotta go to Baltimoooooore! And it has nothing to do with John Waters.)
#5 Peter J DeCrescenzo
Peter J DeCrescenzo
  • 620 posts
Posted 06 August 2005 - 12:29 PM
<{POST_SNAPBACK}>
Interesting. But when my new NTSC DSR-450WSL is in 30p mode, the default ("off") shutter speed appears to be different than when I turn the shutter on (and set it to 1/60-sec.). When this cam is in 30p mode, the shutter speed setting start at 1/40, then 1/60, and up from there. You can't select 1/30 other than turning off the electronic shutter, or by using "ECS" (clear scan).
The exposure which results from the above two settings is quite different -- "off" is brighter, and "on" @ 1/60-sec. is darker -- which is what I'd expect.
I'm guessing the "default/off" shutter speed is 1/30-sec. The camera doesn't display a shutter speed value when the shutter is off.
Does that sound about right? Or do different brand/model cams handle this differently?
All the best,
- Peter
Edited by Peter DeCrescenzo, 06 August 2005 - 12:34 PM.
#6 Brian Wells
Brian Wells
  • 438 posts
Posted 06 August 2005 - 03:32 PM
Hi Peter,
hmm. This is interesting. On the DVX100a, the default isn't really mentioned either. But, 1/30th is noticeably/remarkably brighter than the default. And, 1/60th is slightly darker than the default. It appears the default is stuck somewhere between 1.30th and 1/60th, yet much closer to 1/60th.
(I would post grabs, but I'm about to head out of town.. Sorry)
Hope this helps,
Brian
#7 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 06 August 2005 - 03:34 PM
All the best,
- Peter
<{POST_SNAPBACK}>
That could be right. I haven't had a chance to use one of those cams yet. I suppose that since your shutter speed menu, in 30p, starts at 1/40, that must mean the default is 1/30. That would be different than most of their other cams, though.
Does that camera have "digital super-gain"? I'm shooting (again) with an SDX900 for a week and it has DSG which is VERY cool. It's basically a digital representation of a 1/6 second shutter so the motion is veeeery blurred. Really cool. And you can see in near darkness with little noise. The downside is that it only works in 60i. Not sure why.
#8 Peter J DeCrescenzo
Peter J DeCrescenzo
  • 620 posts
Posted 06 August 2005 - 07:17 PM
<{POST_SNAPBACK}>
The DSR-450WS has a Slow Shutter which is a feature of its interlaced mode (only).
On the NTSC version, Slow Shutter can be set to 1/30, 1/15, 1/10, 1/7.5, 1/6, 1/5, 1/4.3, 1/3.8, and 1/1.9 of a sec. The PAL version offers slightly different Slow Shutter values.
FYI: The user manual for the DSR-400 & DSR-450WS camcorders is now available for download in the "Manuals and DOC's" area of cinematography.com.
All the best,
- Peter
