Broken Flowers
#1 Alain LeTourneau
Alain LeTourneau
  • 355 posts
  • Portland, Oregon USA
Posted 10 August 2005 - 03:30 AM
Anyone know if Jarmusch's Broken Flowers was shot super 16? How about what stocks?
Alain
  • 20072 posts
Posted 10 August 2005 - 11:21 AM
Looked like 35mm but shot through a net, which Fredrick Elmes does a lot of.
#3 Alain LeTourneau
Alain LeTourneau
  • 355 posts
Posted 10 August 2005 - 03:08 PM
<{POST_SNAPBACK}>
Actual gauze, or a pro mist or what? Didn't much care for the look, I like detail.
I don't recall Elmes doing this on Night on Earth, during the static night shots of exterior environments (in each location, separating each sequence). Is this a new things for Elmes?
Alain
#4 David Mullen ASC
  • 20072 posts
Posted 11 August 2005 - 12:31 AM
A net is type of pantyhose material.
No, he shoots thru nets all the time. "Ride with the Devil" and "Kinsey" for example, both shot in anamorphic with nets. He doesn't do it on every film, just many of them.
I think some of "Blue Velvet" used nets but definitely heavier nets were used in "Wild at Heart".
It's just a matter of taste.
The net in "Broken Flowers" is pretty subtle, so I'm not 100% sure, but on some of the glints off of passing cars, you can see a slight fringey star-filter-ish pattern.
#5 Charles Haine
Charles Haine
  • 127 posts
  • Colorist
Posted 15 September 2005 - 07:32 PM
There's something about this film that looked very Melville-like to me, not only the shot of the car alone in the field, but also something about the quality of the cold light. It isn't a CTB blue, but a different, greyer blue that suffuses this movie.
Any idea what was on the lights?
chuck
#6 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 16 September 2005 - 09:19 AM
<{POST_SNAPBACK}>
Yes, using a net (or nylon mesh material from pantyhose) to reduce contrast can act like a mild "star filter" where you can see the diffraction pattern in the specular highlights. Worth bearing in mind as you orient the mesh in front of the lens. The amount of the "stars" seen also depends on the f/stop.
