Will aaton 200ft film length fit acl 200ft mag
36 replies to this topic
#1 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 11 August 2005 - 07:12 AM
Anyone know if the aaton 200ft film lengths will actually fit a 200ft eclair acl mag.
I've been told that they wont because of a different spooling core design, but I would like to know for sure. Many thanks
Rob Spence
#2 Nathan Milford
Nathan Milford
  • 692 posts
  • New York, NY
Posted 11 August 2005 - 08:42 AM
This has been covered half a dozen times. I should probably submit a FAQ article on it or something:
The short answer is: No.
The long answer is: Well... no they won't.
The longer answer is: A-Minima loads are spooled on a special Kodak flanged daylight load that also works as part of the magazine's takeup torque system. The loads are unlike normal 2" Kodak cores and will not initially fit into an ACL 200' mags. A-Minima film is wound emulsion out, 'a-winding' which is backwards from the way other cameras take thier film, emulsion in 'b-winding'.
So why can't I unspool it, rewind it and put it on a core in a b-winding? Because of the natural curl of the film. Since it is wound differently from normal loads, A-Minima loads curl differently, something the A-Minima takes into account for in it's design. I set the flange focal tolerance to +15 to +25 micron (on most cameras its -7 to -14 or so). The A-Minima expects the film to curl into the gate obviating the need for a pressure plate. That curl, which the A-Minima loves so dearly, is an issue on other cameras as they're expecting it to curl the other way. This is a difference of microns, and maybe with longer lenses you might not notice it because the depth of focus as much greater, but nominally, the image projected out the back element of the lens will project beyond the film plane as the film plane is a few microns infront of where it is supposed to be.
- Nathan
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 11 August 2005 - 09:00 AM
Rob Spence
<{POST_SNAPBACK}>
The Kodak Aaton A-Minima loads are designed specifically for that camera:
http://www.kodak.com...e/aminima.jhtml
A-Minima features a quick change magazine which accepts 200' (61m) film loads in a new daylight friendly format on a core with flexible flanges. With a base market price of roughly $15,000 (USD), A-Minima makes high quality filmmaking very affordable.
The following Kodak film stocks are presently manufactured for A-Minima.
If you really MUST have 200 foot rolls for the ACL, better to wind them down from normal 400-foot B-Wind rolls. Pay attention to winding orientation, and rewind film carefully in total darkness.
#4 Oliver Gläser
Oliver Gläser
  • 65 posts
  • Vancouver BC, Canada
Posted 12 August 2005 - 10:19 PM
Just a note. The ACL as is the NPR, are both capable of using A or B wind Film. The cameras take up the same way regardless and depending on your wind you will end up with a take up spool either emulsion in or emulsion out.
Just a question for you john, when did Kodak stop making 200 foot daylight spools. I still have a couple of them in my ACL mags that I keep a tight hold on when the film goes to the lab. Is one still able to find them or only by luck? I suppose that one could concievably get A minima spools and then roll them over to 200 foot daylight spools for use in the mags. just a thought. Ordinarily I simply buy 400 footers and either myself or have the lab spool them down onto the spools and cores. If I do have them put on the large daylight spools then I simply take up to a core and never have a problem.
anyway that's my two cents.... Ok maybe a little more. :D
Oliver Glaser
#5 Mike Welle
Mike Welle
  • 125 posts
Posted 14 August 2005 - 11:22 PM
It's too bad that you should be given misinformation by so many who pretend to know. It's a lot like Shakespeare said: "There are a sort of men whose visages do cream and mantle like a standing pond and do a willful stillness entertain with purpose to be dressed in an opinion of wisdom, gravity, profound conceit." Sure that quote doesn't hit the nail on the head, but please--don't be so prosaic. I'm not going to read any responses.
I was just laughed at for saying that Eclair ACL magazines fall off. Oh guess what a guy is selling one now which has a latch harness attached to it--but nevermind Mike, he doesn't know anything. See:
http://www.the-temenos.org/Sites.html
People say lots of crap that just isn't true. That's history. Look at Richard III, look at President Bush.
Oh and, if you want to listen to me--I've actually used the A-Minima loads on the Eclair--and guess what they do work--the Eclair was designed to take it up A or B wind. "Oh my Antonio, I do know of these that therefore only are reputed wise for saying nothing, when I am very sure if they should speak would almost damn those ears which hearing them would call their brothers fools. I'll tell thee more of this another time."
You have to turn the flanges counterclockwise to remove them. You'll need spare cores on hand, unless you want to tape your film to the take-up core of the A-Minima which doesn't have a slot (nice job Kodak.) Go to Santa Barbara Film and Audio--do a google search--it works really well.
But please don't believe me. I don't know anything.
Have a nice day,
Mike Welle
Rob Spence
<{POST_SNAPBACK}>
#6 Mike Welle
Mike Welle
  • 125 posts
Posted 14 August 2005 - 11:36 PM
See, here is the picture from the manual--now, go ahead and give your spiel about microns or whatever--I for one will not put forth obsequious banter. Please ban me from this list.
Thank you,
Mike Welle
Rob Spence
<{POST_SNAPBACK}>
Edited by Mike Welle, 14 August 2005 - 11:39 PM.
#7 Nathan Milford
Nathan Milford
  • 692 posts
  • New York, NY
Posted 15 August 2005 - 05:57 PM
What is at issue is not the magazine's capacity to take a particular winding. It is the camera's mount being set to expect the film to curl one way. This is why the A-Minima's flange tolerance is in the plus whereas most every other motion picture camera sets it in the negative. If you don't believe 10 microns can affect focus then you should simply relegate yourself to quoting Shakespeare and avoid dispensing camera advice. >8)
#8 Mike Welle
Mike Welle
  • 125 posts
Posted 15 August 2005 - 06:56 PM
Kodak and Aaton are afraid to death about the Eclair ACL. They don't want anyone to buy one because it steals sales of the A-Minima. Kodak won't list it on their website. Why do you think the Kodak and Aaton people immediately responded to this post. Don't sell me film. I can hear you now calling me a fool. I'll be polite enough not to ask if you have ever serviced an ACL--o my god. Attack me! Shake my confidence! Hurl me into the rocks. "I in such a desperate bay of death, like a poor bark of sails and tackling reft, rush all to pieces on thy rocky bosom."
"Blow wind rack, at least we'll die with harness on our back." Don't know if that quote is right--but I know it comes from Macbeth. Attack me. Blow wind. Insult me. Ban me from the list. I am not afraid of the cool breath of death.
Oh, by the way, (tell me I'm wrong--shake my confidence) if you set the camera up for A-Minima loads when you get it converted to Super-16 you won't have any problems. Yes you will! No you won't! Yes you will! No you won't!
Good bye,
Mike Welle
<{POST_SNAPBACK}>
#9 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 15 August 2005 - 07:13 PM
Mike, if you simply stated your opinion and experience instead of treating everything as epic drama you might be taken seriously.
#10 Nathan Milford
Nathan Milford
  • 692 posts
  • New York, NY
Posted 15 August 2005 - 07:37 PM
Wow... I'd like to take a drag off of whatever he is smoking.
*boggles*
#11 Mike Welle
Mike Welle
  • 125 posts
Posted 15 August 2005 - 08:03 PM
Oh, that's so important to me--to be taken seriously guys! I like being picked on by you Republicans--who think I'm completely insane! I know you want a toke of this Nathan. Go ahead keep hurting me. I support George W. Bush and his war on Tara! Oh Rhett take me to Tara! Where I can live with the other Southern racists! I will never be hungry again! Insult me! Insult me! Ban me from the list!
Now here's my scandal:
They used to issue Eclair ACLs with lenses that would open up to T1.9 (I think) for the Angenieux 9.5-57. I was just looking at the manual--and through my purple haze--I saw--I saw--that the Eclair took up A or B wind. Now I know, Nathan (I'm ready for your swing) it doesn't matter. Well apparently the Eclair ACL people could care less whether you loaded your film A or B wind even if you were using the camera at T1.9 with a 9.5mm lens. Now, that isn't a T1.3 Zeiss or Illumina (Nathan--I know how fond you are of these). But you could open up a 9.5mm lens back in the seventies to T1.9 and no Eclair guys would be going--whoa dude your flange focal distance sucks--you better shift that bad boy into 57mm.
Farewell gentlemen, I will be gone to Brecknock while my fearful head is on!
Mike Welle
Earl of Buckingham
The Eclair ACLs were issued
<{POST_SNAPBACK}>
#12 Rik Andino
Rik Andino
  • 783 posts
  • Electrician
  • New York City
Posted 23 August 2005 - 09:36 PM
The simplest way for you to prove to us that you're not a loony Mike
Is for you to grab some A-minima specified film
And then load into an Eclair ACL and then shoot a test...
And please stop quoting the friggin Shakespeare...
This is not an English lit class!
#13 mark leuchter
mark leuchter
  • 53 posts
Posted 27 August 2005 - 04:08 PM
Nathan, I can see how the micron measurement bend of the film would factor into focus calculations for the A-Minma, but if the Eclair ACL is using a pressure plate, wouldn't the film's nature bending be obviated anyway? In other words, while the film's bend works FOR the A-Minima, would not the pressure plate design of the ACL simply neutralize it?
Mark
#14 Mike Welle
Mike Welle
  • 125 posts
Posted 24 January 2006 - 02:21 PM
I believe I was incorrect and I was acting like an ass. But let me set the record straight and humiliate myself in the process.
Well, it turns out that in June of 2005 (before this forum began) I shot 2 or 3 rolls of A-Minima film. For my Christmas present I had it transferred to video at CinePost in Atlanta, GA. Ninety-five percent of it was in focus, but I think that Nathan is correct--and I didn't understand it. Some of the film had focus issues. These were only the scenes shot in low light with my 8mm Optar Illumina. The lens must of been opened to T1.3 or 2, because these were night scenes on Duvall Street at Key West, Florida. I also shot a 100' spool on Duvall with the same lens and it had much better focus. I think that the A-wind film that the A-Minima uses does indeed develop a memory and change the film plane ever so slightly. I intend to ask my camera tech if he can set my camera up so that the A-Minima loads work correctly. I assume that if he resets the ground glass position and that if I send him a roll of the A-Minima film along with the magazines he will be able to get this set up properly.
Edited by Mike Welle, 24 January 2006 - 02:29 PM.
#15 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
Posted 24 January 2006 - 04:38 PM
Film wound emulsion-in has a different "core-set" (clockspring) than film wound emulsion-out. Usually, it takes a few weeks for the film to lose its original core set and take on a new one if it is rewound with a different orientation.
Depth of focus is very shallow with the lens wide open, so any curl or core-set could affect critical focus more in those situations.
#16 Clive Tobin
Clive Tobin
  • 402 posts
  • Spokane Valley, WA, USA
Posted 24 January 2006 - 06:47 PM
...If you really MUST have 200 foot rolls for the ACL, better to wind them down from normal 400-foot B-Wind rolls. ...
John, this has been bugging me for some time:
It appears that Kodak is not following normal terminology when calling the A-Minima loads "A Wind."
In the Kodak price list, it is stated that Wind designations apply to film that is wound emulsion in. B Wind has holes on the right, and A Wind has holes on the left. This terminology is standard for intermediate and print films and has been for decades.
Should not the A-Minima loads be called "B Wind Emulsion Out" instead? Calling it "A Wind" makes users think that the holes are on the wrong side and won't fit the projector or printer etc.
#17 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
Posted 24 January 2006 - 09:26 PM
Interesting. I'll have to run that one by the perforating engineers. Thanks.
#18 Scott Bullock
Scott Bullock
  • 245 posts
  • Denver, CO
Posted 01 March 2006 - 09:07 PM
Okay, let's see if I have this figured out correctly: An ACL user with 200' mags. could conceivably use A-Minima specific film for his/her camera if . . .
A) They abandoned the A-Minima type spool in favor of cores and/or daylight spools providing that they allow time (a few weeks) for their re-spooled film to adjust to a new core set, or . . .
B} They ignored the Aaton specific loads altogether and simply rolled off film from a 400 ft. roll onto 200' spools or cores before loading it into 200' ACL magazines.
Am I missing anything?
#19 Mike Welle
Mike Welle
  • 125 posts
Posted 01 March 2006 - 11:40 PM
What I am going to try next is to send my camera to Du-All in New York and ask if they can set up the flange focal/back focus setting (you know what I mean) so that A-wind, A-Minima film will work properly because Nathan said in another post that the film tends to bow toward or away from the gate (can't remember specifically) a few microns--and my camera (must be) set up to take B-wind film--just like everyone elses is as well. That was not very well written, I know. I will let the forum know the results of this experience in several months. When I was shooting in Key West, I think this was confirmed with my 8mm Optar Illumina wide angle at (T1.3-2.2). At all other settings footage was in focus. In my opinion the easiest thing to do would be to a) leave your camera alone or B) try sending it to a technician who can reset the back focus/flange focal setting. You might want to wait until I've been the guinea pig on this. I'm not sure I agree and/or understand the whole "core set" business and am frankly, quite skeptical of it. And since you cannot reason with a man that looks not heavily and full of fear, maybe it's just easier to shoot 100' spools and enjoy your camera. Maybe 200' loads are chasing something not worth the search. Remember what Shakespeare said: "All things that are are with more spirit chased than enjoyed."
Edited by Mike Welle, 01 March 2006 - 11:46 PM.
#20 Scott Bullock
Scott Bullock
  • 245 posts
  • Denver, CO
Posted 02 March 2006 - 10:36 AM
Well, like I said, if I'm understanding what everyone is saying, you can use a 200' load if a) they are taken from 400' loads, b} you use short/medium ends from 400' loads, or c) you discard the A-minima spool, re-spool the film onto a core or daylight spool with the proper wind, and allow the film to sit for a few weeks until it establishes a new core set.
Am I right in assuming that these 3 options are correct? Anyone?
