Best Setup for DX900
#1 Daniel Andreas
Daniel Andreas
  • 29 posts
  • Santa Monica
Posted 14 August 2005 - 05:23 PM
We are shooting a short film on two SDX900s with DigiPrimes.
The producers are hoping to be able to afford a Film-Out
-- although at this point we are not 100% certain that will happen.
Is there a setup that looks great both on a Film-Out as well as direct to DVD that is already on the CD-Rom?
Most of the scenes are interiors, some daylite, some tungsten.
If it has to be done manually:
Which Gamma is best?
Is FilmLike1 or FilmLike2 recommended?
Where should Master Ped, Black Stretch Level, Kneepoint, Kneeslope etc. be?
Where should the Horizontal DTL and Vertical DTL be?
What other settings need to be tweaked?
I assume the preferred Record Mode is 24PA ? Is that true even if we DONT go to film?
Should I shoot at -3dB gain or is there no advantage over shooting at 0dB?
What else do I need to look out for?
Greatful for any insight from anybody who has experience with setting up the SDX for Film-Outs
#2 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 14 August 2005 - 09:24 PM
<{POST_SNAPBACK}>
This is something you should first discuss with the people who will be doing the film-out. They will have recommendations for the key settings and then you can try to take that into account when deciding on the look you're after.
Here's some info from a place that does film-outs:
http://www.swisseffe...ages/e_tape.htm
#3 Daniel Andreas
Daniel Andreas
  • 29 posts
  • Santa Monica
Posted 15 August 2005 - 01:31 AM
<{POST_SNAPBACK}>
I have already contacted Swiss Effects and should be getting an answer soon.
They are the BEST and I am friends with some top people there, but thanks anyway.
I am just looking for a DP who has done Film-Outs with SDX before, ideally through SwissFX or DuArt
#4 Chris Sharman
Chris Sharman
  • 15 posts
Posted 16 September 2005 - 06:46 AM
The advantage of shooting at -3dB is that it allows you to open up the lens half a stop for a shallower depth of field.
JM
#5 Alvin Pingol
Alvin Pingol
  • 677 posts
  • California
Posted 17 September 2005 - 02:26 AM
It also allows for an image with slightly less noise, as the anologue signal will not be amplified as much. Of course, I'm sure the SDX does not suffer from much noise at all at 0dB anyway...
