Help understanding Bolex battery power (amp hours)
#1 Craig Knowles
Craig Knowles
  • 182 posts
  • Cleveland
Posted 22 August 2005 - 12:24 AM
Can someone please explain to me the concept of "amp hours" in the context of battery power?
I have a Bolex EBM, which takes an internal "12v 1.2Ah" (amp hour) battery. I'd like to use an external source, specifically a Bescor 12v battery belt. Shelton Communcation has a Bescor "12v 3.4Ah" battery.
1) Is it safe to use this a "12v 3.4 Ah" battery with the Bolex, or will the "3.4 Ah" somehow overload the camera, as it only requires "1.2 Ah"?
2) Or, is Ah a measure of current over time and thus not at all related to power?
3) If this were the case, then could I use, say a "12v 14Ah" battery without frying the camera as well?
Thanks in advance,
Craig
#2 Evan Kubota
Evan Kubota
  • 32 posts
Posted 22 August 2005 - 12:39 AM
Amps are a measure of current over time, as you said. The camera will only draw what it needs - if the current the camera draws is (estimate - not accurate) 2 A, a 3.4 A battery will give you around 85 minutes of operating time. As long as the voltage is the same as the internal battery you're fine.
Thanks in advance,
Craig
<{POST_SNAPBACK}>
