Lighting kit advice, which softlight if any?
#1 jack ratigan
jack ratigan
Posted 22 August 2005 - 10:06 AM
Hi all,
I am at present trying to put together a lighting kit mainly for independent short films on DV which are for the most part shot in regular size house rooms etc.
Where I live, I can rent red heads/blondes quite cheaply so didn?t really want to buy these, I have opted firstly for 3 150 watt dedo lights as a start.
What I am really wondering is whether I need to invest in a soft light such as a Photoflex Starlight or Rifa light, will this type of light really give me more light control than a bounced redhead or several redheads through a diffusion frame for example.
Any advice would be much appreciated, thanks, JR
#2 Phil Rhodes
  • 12167 posts
Posted 22 August 2005 - 02:05 PM
If you're going to do something like that, I'd look at fluorescent for compactness and efficiency. And frankly, if you don't have pro clients to impress, they're such a complete no-brainer to build that I wouldn't hesitate to do so again.
Phil
#3 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 23 August 2005 - 07:08 AM
Check the big thread about soflights. But the bigger the source relative to the object, the softer the light. Therefore a blonde bounced into a white wall next to your actor will be much softer than a Rifa light on the same actor. Bouncing eliminates direct light and is a good way to achieve softness.
The Rifa's are nice, though. I use them a lot and they're compact and easy to transport and rig. My only complaint is that the bulb goes a bit to often. Luckily, it isn't very expensive.
