Fastest 16mm C-mount lens
#1 Craig Knowles
Craig Knowles
  • 182 posts
  • Cleveland
Posted 24 August 2005 - 11:03 PM
I've got a shoot coming up inside a dark room, seemingly lit only by hand-held lanterns and flashlights. I can put more light in the room, but it has to look like it's coming from these elements.
What's the fastest C-Mount 16mm lens I'm going to be able to get my hands on? A 1.4 is the fastest I've seen around so far.
Thanks.
Edited by Craig Knowles, 24 August 2005 - 11:04 PM.
#2 A.Oliver
A.Oliver
  • 348 posts
  • Croydon UK
Posted 25 August 2005 - 02:44 AM
Hi, the fastest c-mount lens i have used is an angenieux 25mm f0.95, gave good results. You could look out for schneider cine xenon lenses, only f1.4 though. Or a zeiss 9.5,12,16 or 25mm in arri bayonet mount and use a c-mount converter, these are f1.2. You may get away with f1.4 glass and use 7218 stock, i have been stunned with the stocks low lite capabilities.
#3 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 25 August 2005 - 09:59 AM
I have seen a Comistar f1.2 before.
But the Agineaux 0.95 is the fastest c-mount I've seen in general use, very sharp.
#4 Robert Hughes
Robert Hughes
  • 873 posts
  • Sound Department
  • Minneapolis
Posted 25 August 2005 - 03:03 PM
But keep in mind that the depth of field at f/0.95 is almost zero; you have to be spot on with your focus, otherwise you'll wind up with a lot of properly exposed but blurry film.
#5 Michael Carter
Michael Carter
Posted 25 August 2005 - 08:59 PM
Don't neglet that old cameras often have 1/30 sec at 16fps. You could also shoot at 8fps and have everyone move slowly :D
#6 Michael Maier
Michael Maier
  • 216 posts
Posted 10 September 2005 - 07:45 PM
<{POST_SNAPBACK}>
Actually, the information I have is that Angenieux 25mm f0.95 is a re-housed Schneider Xenon 25mm f0.95. So Schneider also has a f0.95 lens and it's the very same glass of the Angenieux you mention.
#7 andres victorero
andres victorero
  • 412 posts
  • Spain
Posted 15 September 2005 - 02:44 PM
could be a decent solution to buy a c mount adapter for still nikon - canon - olympues lenses?
