how would you do this effect?
29 replies to this topic
#1 Delorme Jean-Marie
Delorme Jean-Marie
  • 513 posts
  • paris, france
Posted 30 August 2005 - 04:10 PM
hi i have a new question, (i hope i'm not abusing of the kindness of the members of this forum)
i need to do a effect on a child face, it' s at night, outdoor, a flash lightning comming from what the child is looking at. He is actualy looking at a body surrounded by electricity, (like the dolorean in back to the future...)
i thought about turning on an hmi arc but i'm scared to be too green and hard to control.
how would you do this?
#2 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 30 August 2005 - 05:06 PM
Assuming that you want a blueish lightning effect, and that your shot is at least an MCU, why not just flash a 650w or a 1k with 1/2 or full blue on it from the direction your actor is looking?
There are many ways of doing this effect, but I think this is probably the simplest.
#3 Lars.Erik
Lars.Erik
  • 175 posts
  • Steadicam Operator
  • Oslo
Posted 30 August 2005 - 05:36 PM
What about the company that has designed lamps just for these purposes?
http://www.lightningstrikes.com
Turning on a HMI arc will give a greenish light at first, as you stated.
#4 fstop
fstop
Posted 30 August 2005 - 05:58 PM
Listen to Stuart.
P.S: why do Lightningstrikes even bother sticking Beverly Hills Cop 3 on their credits list? :blink:
#5 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 30 August 2005 - 06:30 PM
If it's just the child's face that needs illuminating I think Lightning Strikes would be way overkill. How about a cheap fluorescent fixture with a conventional blink-blink starter? It won't be a point source, which could help the gag, and the falloff will leave the background largely unaffected. You can syncopate your switch operation with the strike time of the tube for a continuous flickering.
#6 David Mullen ASC
  • 20069 posts
Posted 30 August 2005 - 09:28 PM
I usually rent some metal venetian blind-type shutters from a lighting house and put that in front of an HMI... slap them open and close real fast & randomly.
#7 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 31 August 2005 - 11:08 PM
I've used a photographer's flash before. It was cheap, fast, easy, and worked okay. The only thing I didn't like about it was that it was too fast (about 3 frames).
#8 Bob Hayes
Bob Hayes
  • 1087 posts
  • Culver City, California
Posted 01 September 2005 - 02:16 AM
If you want the effect to look like the lighting around the Delorean in ?Back to the Future? I think I?d bounce a couple of bright lights, 1K pars for example, with Full blue into some crumpled up shinny aluminum foil taped to a card board. Put the lights on dimmers so you can bring the electricity up from nothing.
#9 Tomas Koolhaas
Tomas Koolhaas
  • 334 posts
  • los angeles
Posted 04 September 2005 - 05:51 PM
Hello,
There are also many types of Flicker boxes for rent that have pre-set lightning settings which you can use. You could get one that has outputs for multiple lights which can be dimmed and set to trigger at different increments and for different durations, independent of each other, this may be the easiest way to simulate electricity flickering.
Cheers.
#10 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 07 September 2005 - 05:43 PM
<{POST_SNAPBACK}>
Could try getting an arc welder and bouncing some of the strike back onto the face. Direct light might be too dangerous for talent so bounce it off some foil.
#11 Robert Hughes
Robert Hughes
  • 873 posts
  • Sound Department
  • Minneapolis
Posted 08 September 2005 - 10:07 AM
In old Hollywood I believe they achieved lightning effects by momentarily striking carbon arc lamps. So the arc welder option should likely give a similar effect.
#12 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
  • Athens, Greece, London UK
Posted 08 September 2005 - 03:39 PM
Lol,
Nice advises, most of them will do the effect, it's just what is the film sensitivity?
Are u shooting 25 fps? or 150 fps? Super duper telephoto lens or a high speed one?
Regards
Dimitrios Koukas
#13 Kenny N Suleimanagich
  • 902 posts
Posted 11 April 2007 - 08:18 PM
It might be a bit too much, but I know someone who used to handle scissor-arcs which are basically a bunch of positive carbons and a bunch of negative carbons, both charged with I BELIEVE 115V and then when you need the flash the scissors close and produce the huge flash. Its like when you're striking a carbon arc but much more and much quicker.
#14 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 11 April 2007 - 09:04 PM
It's interesting how so many people forget about those shutters, David. I suppose this day & age people automatically try and go for the more high technology way of achieving the effect...when really, it's been there all along. Tucked away in the annals of history, more specifically in Alton's "Painting with Light".
#15 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 11 April 2007 - 09:44 PM
The shutters can work well, though I usually rent strobes called "AF1000s" or the older versions were called "Dataflashes" by High End Systems (formally Lightwave Research).
These are pretty cheap, DMX controlled, extremely high output Xenon strobes that can do constant output and everything in between. They rent for like $30 a day or so, I usually rent 4 of them with a DMX controller that is made for them.
Kevin Zanit
#16 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 11 April 2007 - 09:50 PM
Are you talking about the ol' flaming napalm held above the photographers head ?
Flashes fire usually in the range of a factor of 10 to 200 times faster than an open shutter (24fps, 180deg) - ie. they can flash on and off many times whilst the shutter is closed and the film will never see it... (if it can recharge that fast and/or has a big cap reservoir to begin with).
#17 Richard Andrewski
Richard Andrewski
  • 134 posts
  • Shenzhen, China
Posted 11 April 2007 - 11:47 PM
The main problem with HMI's for this kind of effect is that they may not have hot restrike which means you have a period to wait before they'll turn on again. Of course, if you use the shutters in front of an HMI to achieve the effect, that's another story. Shouldn't have too much of a green spike after the light has been on a for a minute or so if the bulb is a good one.
#18 Kenny N Suleimanagich
  • 902 posts
Posted 12 April 2007 - 03:20 AM
why not just have a tungsten light with a macbeth glass instead of an HMI...
#19 JD Hartman
JD Hartman
  • 1763 posts
  • Edison, N.J. U.S.A.
Posted 12 April 2007 - 08:55 AM
I'd have to agree with the suggestion to use shutters in front of the light source. Simple solutions usually work out the best. The old style carbon rod, lightning units were cabled to an arc welder (large DC power source). Elecric arcs produce ultra violet radiation in large quantites, not something you want near the talent or the crew. Welders call the resulting cornea burn, "sand in the eyes". Its temporary effect can last for up to 24 hours. Not pleasant.
Edited by JD Hartman, 12 April 2007 - 08:57 AM.
#20 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 12 April 2007 - 05:51 PM
what's a macbeth glass ?
Never mind, found it. Seen em before just didn't know what they were called.
