Foot candles conversion
#1 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 31 August 2005 - 01:09 PM
So according to Kodak's technical data on their website their 500T Vision 2 stock needs 80 ft candles to be exposed at normal. But this is based on a shutter angle of 170 degrees.
So for the Bolex with it's 133 degree shutter and prism the light exposing the film is 1/80th of a second. Which is about 1.6667 times slower than 1/48th of a second. So therefore it should take 133 ft candles to expose film on an RX5 Bolex at an f-stop of 5.6?
#2 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 31 August 2005 - 01:42 PM
<{POST_SNAPBACK}>
Yes, you need 80 footcandles with a 170 degree shutter opening and 24fps for a T-5.6 stop with a EI500T film.
So for a 133 degree shutter opening:
(170/133) x 80 = 102 footcandles.
#3 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 31 August 2005 - 03:34 PM
<{POST_SNAPBACK}>
Yes, ok, and I'm using RX lenses so I'm not calculating for 1/80 of a second I'm calculating for 1/65.
Thanks!
#4 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 31 August 2005 - 10:42 PM
Not meaning to be picky, but 1/80th of a second is actually faster than 1/48th of a second, not slower.
Still, you are correct in saying you therefore need more light.
If a 170deg shutter is run at 24fps, then the exposure is 1/51th sec and a 133deg shutter will expose for 1/65th sec.
But you can work out the light you need just from the angles. If you need 80fc at 170 deg, then you need (80 x 170/133) = 102fc at 133 deg.
