Projectors 1280x720 do they degrade the image?
#1 Alex Lindblom
Alex Lindblom
  • 109 posts
Posted 01 September 2005 - 04:04 AM
Can somebody please explain this to me, I am going crazy thinking about it?
Projectors in the native 1280x720 format when they play back a DVD in 720x576/480. Do they have to rescale it to fit to the larger matrix, and by doing so actually degrading the picture quality?
If it so why aren?t anybody producing 720x576 chips?
And also how does the DLP chips in 858 x 480 deal whit the, higher resolution of PAL DVD?s?
#2 Filip Plesha
Filip Plesha
  • 1267 posts
  • Croatia
Posted 01 September 2005 - 09:11 AM
you can't watch a DVD image that is not rescaled, even if you have a PAL resolution TV because the picture is mostly anamorphic, which means it has to be stretched to 1024x576 in order for you to see it. So it is always degraded (softened) no matter what display you use
#3 Alex Lindblom
Alex Lindblom
  • 109 posts
Posted 01 September 2005 - 01:52 PM
Yes...
But an anamorphic DVD in 1.78:1 still uses the full resolution of 720x576/480 and no scaling is used with a normal widescreen CRT TV, it?s not much different from using an anamorphic lenses in theatres to un squeeze the image ( the principal not the quality ).
Edited by Alex Lindblom, 01 September 2005 - 01:57 PM.
#4 David Mullen ASC
Posted 01 September 2005 - 03:46 PM
I don't know, but DVD's look great to me played on a consumer HDTV monitor...
#5 Filip Plesha
Filip Plesha
  • 1267 posts
  • Croatia
Posted 04 September 2005 - 09:56 AM
Yes...
<{POST_SNAPBACK}>
Yes, I forgot about widescreen SD TV's.
