Light Meter
9 replies to this topic
#1 Sarfaraz M H Merchant
  • 11 posts
Posted 04 September 2005 - 04:11 PM
I have a very old light meter, and need to upgrade for a short I am shooting on 16mm soon.
Picking a new light meter has been so confusing with all the extra features (I have thought about the L608 seckonic or the 558c). How useful will I find many of these features? and will they really help me produce better images?
(I am almost entielry self taught in Cine. and not that well experianced).
Any advise, or experiance would be most appreciated.
Edited by Sarfaraz Kaus, 04 September 2005 - 04:12 PM.
#2 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 05 September 2005 - 11:00 AM
Hello,
I recently got the Sekonic L-558C. I love it. However, it is a complicated widget and has a learning curve to it. I was like you. I used a Calcu-lite for years and years and it had the old LED read-out and conversion wheel. If you don't mind the newer LCD readouts and buttons with a gazzillion options, the Sekonic will do a good job for both ambient and spot. I really like the FC reads on it.
#3 David E. McMurray
David E. McMurray
  • 17 posts
Posted 06 September 2005 - 03:02 AM
<{POST_SNAPBACK}>
I have always used and old fashioned analog light meter. A red needle over numbers is much more intuative than digital numbers running up and down like a gas pump.
I use the white flat disk to measure the light falling on the different objects in the scene. I never use the globe. I want to know what the light is coming from a specific direction and adjust it accordingly. But I must always take the time to walk around my objects in the scene so I know what is going on. It is not a quick way to do things. Use your hand and body to block light from particular lights you are not interested in metering. For eye sockets or other recessed areas.
Don't get focused on the gadget. Think in broad terms. The camera pushes film. The most important part is the lens. In Film.
Yours,
Dave
P.S. The metering technique is Alan Daviau's A.S.C.
#4 Mikael Lemercier
Mikael Lemercier
  • 43 posts
  • France, world.
Posted 06 September 2005 - 03:11 AM
HI SARFARAZ,
i work with a professional SPECTRA IV.
it's great.
best.
Mikael.
#5 Sarfaraz M H Merchant
  • 11 posts
Posted 10 September 2005 - 08:10 PM
Thank you guys, I appreciate your advise, I will try and remain in budget and not get too distracted by the extras till I have the cash.
Some day maybe.
Love and respect,
Saff
#6 Matt Irwin
Matt Irwin
  • 389 posts
Posted 11 September 2005 - 03:20 AM
You don't need a high end meter to make better images. I use a studio studio deluxe and I know at least one ASC member that uses the same meter. Conrad Hall Sr. used a classic spectra- that design hasen't changed in decades. As long as your meter is calibrated and you know how to use it, you should be fine.
#7 L K Keerthi Basu
L K Keerthi Basu
  • 128 posts
  • india
Posted 11 September 2005 - 10:46 AM
I use Sekonic L398M studio deluxe, This is a good meter I have ever used Because i masted this meter so with this i had correct exposures. Its all about the way you use it.
L.K.Keerthibasu
#8 Chris Keth
Posted 11 September 2005 - 12:49 PM
L.K.Keerthibasu
<{POST_SNAPBACK}>
As long as the meter is spot on (or you're used to making mental adjustments for it's inaccuracy ;)) you can make great exposures.
I have an old spectra professional and a Minolta digital spotmeter, both of which I love.
#9 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
Posted 11 September 2005 - 03:29 PM
Hey Saf,
One of the benefits of a do-all meter like the 558C is that whatever calibration variations you encounter, the variation will be the same in that one do-all meter no matter what type of read you go for. None of my 4 meters read sufficiently close to each other to depend on them as a whole. At least the 558C goofs up the same way for all types of readings. That keeps me from exposure variations from spot reads on the Pentax as opposed to ambient reads on my Quantum. My Quantum Calcu-lite just came back from calibration and I still don't trust it fully.
#10 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 11 September 2005 - 06:17 PM
Hey Saf,
<{POST_SNAPBACK}>
Apparently some meters have an 18% grey scale nominal setting and others 16% depending on brand.
Edited by glenn@uow.edu.au, 11 September 2005 - 06:18 PM.
