kodak B/W Print positive 7302 - ASA?
#1 Richard Tuohy
Richard Tuohy
  • 482 posts
  • Daylesford, Australia
Posted 08 September 2005 - 07:41 PM
G'day,
I want to try some experiments with using Kodak's BW print stock (7302) as a high contrast (and very slow!) camera stock. I have heard ASA ratings from 3 to 12. Actually, one thing I want to do is cross process the stock as a reversal which would efectively double the asa. Kodak don't seem to have the asa of this stock listed on their web site.
Anyone help?
Richard T.
#2 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 08 September 2005 - 09:03 PM
G'day,
Anyone help?
Richard T.
<{POST_SNAPBACK}>
Speed ratings (EI) are only applied to camera stocks.
Although Kodak publishes sensitometric data for all its motion picture films, it's hard to compare a blue-only sensitive stock like 7302 with a panchromatic camera stock. With a non-standard reversal process, you are on your own.
I'd suggest starting at EI 3, and run a wide exposure series to narrow down the speed for your conditions.
#3 Richard Tuohy
Richard Tuohy
  • 482 posts
Posted 08 September 2005 - 09:40 PM
Thanks for that John,
I see. I realised it was not panchromatic, but that explains why no asa! I will have to do tests.
R.P.T.
#4 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 08 September 2005 - 10:00 PM
Oh yes, you certainly will. That's the joy of playing with non-standard stocks and processes.
With normal processing, B/W print stock has a gamma about 4 times that of B/W negative, and consequently, is very exposure-critical. Half a stop either way will make a massive difference to the image, as the stock can record a brightness range of only 3 or 4 stops (depending what gamma you process to).
If you want more than blue-only sensitivity, you might try panchromatic sound negative stock 2374. Beware - it's polyester based.
